Topic: ok one last time bbk (Read 1014 times) previous topic - next topic
ok just before i take the 400$ leap is there any issues with clearance or sensor placement on bbk shortie headers and aftermarket x pipe?
thanks alot
x-pipe? do you have a manual trans. i don't recall any x-pipes that will clear auto trans.
My BBK X-Pipe was too close to my AOD. The shift linkage wanted to turn right into it.
You could ding the  out of the pipe and make it work, but I think I converted the shift linkage to the Mustang setup (It either rotated upward instead of downward, or it was just mounted much closer to the transmission body. I don't remember exactly, now). This was functional but really didn't work too well, and I changed to a T5 shortly thereafter. Sorry, my memory is fuzzy about it, but I can tell you that you will definitely have some clearance issues to work out.
 --Ed
"1FSTCAT" - 87 Mercury Cougar XR7, 5 Speed, Powerdyne Supercharger.
"NTRCPTR" - 91 Crown Vic Police Interceptor - 460 POWERED. 14.15 @ 97 MPH, untuned.
Ed's right, I tried a BBK X on my Bird and it was all over the stock shift linkage... Rather than hack it up I put my Hooker H pipe back on.
Here's three pipes for comparo... 1st is a LSC Lincoln, 2nd is my Hooker H and last is the BBK X... Note how the left pipe curves more inward than the others...
thanks guys
