Topic: BM's 88 Cougar build (Read 44873 times) previous topic - next topic
Reply #60
There's a new one on the Corral for $50.00. I've never had any issues with anyone on the Corral. They always sent what they said they would. Just check to see how long they have been a member. and their feedback. If I can help,let me know. What kind of dome light lens do you need. I have a few. If I have what you need, I'll ship you one this week. No charge. I don't need it.
Reply #61
Well, the cam sold. If you post a "want to buy" thread for the cam and speed density computer on the Corrral and here, someone will fix you up. I'll look around.
Reply #62
Thank you Vinnie. I need the lense that goes between the map lamps in the headliner. I have a cam and there is a member here that has a 87 computer for $35. Im a little worried about the harnesses are different between the 87 and 88. Do you know if it will work without repinning?
Reply #63
You should be fine. Install the components under the hood, replace the stock computer with the H.O computer, start the car.You should be fine.I do believe there are a couple of small differences between the '87 and '88 harness, but you are not swapping harnesses, so, you should be fine.
PM me your address and I'll get the lens to you this week.
Reply #64
Thank you very much Vinnie.
Reply #65
I filled the cougar up today. I guess my eco gauge is wrong. I went 138 miles on 8.5 gallons. The math comes out to 16.2 MPG. The eco gauge says 13.7 MPG. Anyone have any ideas to correct the gauge. There is still room for gas mileage improvement.
Reply #66
Re-set the fuel econ gauge and see what happens.
Reply #67
Yeah I did that about a month ago. I'll try it again.
Reply #68
I had a awesome birthday. I got all of my parts today and my wife took me to dinner and it ended up being a surprize party. I haven't taking any pictures yet but I'll be sure to get some tomorrow. I might bore the block tomorrow if I can get the boring bar to work right. I'm going to have to deck the block too, these pistons have huge valve releafs. I'm excited now.
Reply #69
We couldnt get the boring bar to work today so I dropped my block off at my other friends shop. He's going to bore it for $80. Other than that nothing new.
Reply #70
I got my block back from my friend today. He did a great job, all of the cylinders are within a .0005 of each other. I still haven't polished my crank to see if its going standard. My rods are good. I might be able to build my short block this week. I still need to install the cam bearings, freeze plugs, and hang my pistons on the rods. I took pictures today but I forgot my camera at the shop. I'll post some pics tomorrow.
Reply #71
Sweet. Pics are a must.
Reply #72
I loaded some pictures today.
My block.
Here's some of the rough cut pics of the port job.
Reply #73
And I cant forget Vinnie. You're my hero.
Reply #74
I got my computer today. $50
Does anyone know if this is the right one? It says DA1 but there is a sticker on the bake that says 3.0 taurus. Its the warrenty sticker. I think they might have put it on so that they could keep the warrenty. I can tell its not the original cause I can see old glue from the old sticker.
