Topic: 1988 TC single Holset turbo 5.0/ 4R70W (Read 366167 times) previous topic - next topic
Reply #570
Quote from: 347Thunder;368743
the flexible paint/ primer don't do !!!! the trick is put your paint on as thin as possible to keep it from cracking, I used flex agent on my bumper and you saw how it cracked.LOL looking good now your coming down the home stretch, just....a....little.....more
Good advice. I'll be sanding down the bumper pretty good. Just 2 wet coats of primer.
Your bumper cracked and so did your bumper support!! LOL  Seriously, thanks for the support. Your car looks fantastic. Mine isn't going to be as smooth since it looks like you sanded and buffed the clear flat.
What did you use to put your outer door handles back on? Big rivets or some other kind of hardware?
Reply #571
On my 92 mustang door handles, I used 1/4-20 (or 5/16 - I can't remember) stainless allen-head bolts with stainless washer and lock nuts on the back side.  It looks good in my opinion.
Are you going with body color door handles or trim black?
Reply #572
Quote from: The Shredder;368748
Thanks Shredder.
I got some new black handles from Ebay. I was thinking of something similar. Maybe some flattened head star bit bolts or something. Stainless is a good idea, too. I'm going to treat and paint the metal on the handle so it won't rust as fast.
I just ordered tires for my pickup truck. Prices for tires are silly right now.
Reply #573
I bolted my new handles on also, works great.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Reply #574
Quote from: flylear45;368745
I drilled out the holes to 3/8 and installed riv nut 1/4x20 with socket head cap screws
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Reply #575
There's an idea!
I do have a rivnut tool kicking around the shop. Triumph's use them in some places.
Reply #576
I just bolted my handles on as well, with stainless fasteners.
Reply #577
Quote from: Chuck W;368769
Sounds like the way to go. No problem with them loosening, then. I'll definitely get nylock nuts if I don't use the rivnuts.
Reply #579
Wow..... that paint looks nice. Got some pics of the rest of the car?
Reply #580
Quote from: flylear45;368842
No issues. Used nyloc nuts.
Reply #581
Quote from: flylear45;368881
X2 Great paint.
Reply #582
It is a 1992 Mustang Convertible in Titanium Frost...
Reply #583
Sharp car!!
Reply #584
Super sharp 'stang Shredder. Understated and squeaky clean. Very very nice.
