Topic: the cougar is DONE!!!!.... HO/E303/MAS/T5 conversion complete. Drive Video added (Read 13795 times) previous topic - next topic
gone! I think the line going into the evaporator in the heater box has a crack in it, so I got rid of the AC.
Should have just changed out the evap,3.0h job to be sure but well worth it with the humidity in ontario.
You going to mapleview tommorow if you get her running?????
Might be there if it doesn't thunderstorm.
I cant this week, but I will be there next week.
Np
His A/C is in the same place as mine. S PILE!
Looks great so far RJ. You going to modify the baffle for your cobra intake, or just try to find an explorer lower?
It's Gumby's fault.
just got done making a baffle for it... THANKS Kitzdnm!  I went to my parents place and printed out the template off of T Moss' site...
now I am just waiting for a buddy to get off work so I can go grab a set of 19lb'ers off of him, then I gotta figure out the wiring...  Where is the info for wiring up the MAS?
AAAAAAARRRRRRRRGGGGGH !!!!!!! Sorry for the delay.I JUST read all the posts.Man,I've been slacking....a LOT !! My E303 is working great,lumpy idle (has scared off a few potential races),and I've had ZERO interference with my pistons (flat tops).I've had the car to at least 6,ooo rpm's with no worries.(I need a factory tach that goes to 8,000).Anyway,I have the E-303,works great,and the Mass Air ,well,it's all in the signature.No worries at all.Go ahead and get it done and don't lose any sleep over it.Next up,my 5 speed.HOPEFULLY the pedal assembly will be in saturday.Any work I do I'll take pics.I haven't had the time and or weather to do anything.Saturday will be the start I hope.
Quote from: 1WLD BRD;227676
http://www.coolcats.net/tech/advanced/massair.html
:brick:
1979 Ford Fairmont
[/B]
DOH!!  I was looking at an old version I printed...  thanks....  now one more quick question...
I dont have those colors (except the red one) in my MAS harness, so I am going to assume that they are in order from the red one going from right to left?....  my next wire is yellow/black stripe, (ground) then yellow/white stripe,(MAF signal ground) then yellow/Red stripe (MAF signal)...  I took the harness from my old '89 3.8L SC XR-7 harness...
guess it wont hurt to just try it, just as soon as the rain quits....
Reply #39
what ecm are you using?
1979 Ford Fairmont
[/B]
Reply #40
I'm using an A9P.I'll probably keep the same computer for the 5 speed swap as well since it goes both ways.LOL.
Reply #41
vinnie-did you ever find out for sure you got the ecm
i sent you ? never heard .hope all is going great--irv
Reply #42
Quote from: 32VFoxBird;227703
A9L
Edit:
Just came in from working on it... 12:33am...
only thing left to do is change the oil, and wire up the MAS, then hit the key and hope it starts...  should have it up and running in the morning....
Reply #43
I sent you a email with a simple easy to use diagragm.
Reply #44
Here it is.
