Topic: Shorter belt to by pass the air pump? (Read 3112 times) previous topic - next topic
So I'm doing the HO swap as we speak and I'm eliminating the air pump and all it's tubes and such. Do I have to either run the air pump disconected or run an eliminator bracket, or is their a shorter belt that will by pass the air pump but still run the water pump, A/C, power steering, and alternator? I'd rather just not bother with the eliminator and clean up the front of the engine a bit if possible. Thanks :D
Remove pump and bracket and run a shorter belt.  You don't need an eliminator or anything like that.
I figured I could do that but thanks for the reassurance. Any idea on a belt part# that would fit? If anybody knows that would be nice.
You can run a piece of string or rope around it to come up with something close and just make sure you can return if it don't fit.
Bryan
I did the samwe thing,but I don't remember the length,sorry.I ran a string around the pulleys and got a ball park figure and then drove to Autozone to change belst (you can bypass it with the pump still on.I messed with belts in their parking lot so I wouldn't have to buy 6 belts or keep driving back and forth.I eliminated my a/c as well.It never worked,and I am used to not having it after 8 years.
re belt
a 77 inch belt works
The non a/c belt works then. Cool. Just a dumb question but do you have a picture of how it should be routed?
Thats what I used on my car. I don't have a pic but it just goes from the crank pully to the alt pully.
Ok I'll figure it out. I just have to make sure it runs the same way or I'll spin the water pump in the wrong direction :hick:
I did have one.
The non-A/C belt also fits if you still have the A/C and you Power Steering pump seizes and burns your belt off. :flame:
You can bypass the power steering pump and go straight over the A/C compressor. So what i am trying to say is A non-A/C belt is the proper length to bypass the power steering pump and keep the A/C compressor if need be.
Just some, probably useless, information from my own personal experience.:hick: :hick:
Its not very fun trying to park the car with no power steering though.
So are you saying that if I do this I'll screw up my power steering pump or that if the pump goes my belt will fry? I figure that if the power steering pump goes my belt is fried either with or with out the idler pully.
Thanks for the pic slamedcat:D
Just install the belt and you'll be fine.No worries.I've been without smog equipment for a long time (no a/c either),and have never had any issues.Don't look to deep into this subject.Get the belt.Install the belt.Forget about the belt.Enjoy the car.That's it.
What about on an older bird like mine. I have the ALT and air pump on a serp belt and the water punp and PS on the V belt. Right now I'm just running the air pump disconnected and it's spinning free. Works OK for me
