Topic: Shorter belt to by pass the air pump? (Read 3177 times) previous topic - next topic
^^^ yeah i might eliminate my air pump too. sittin there pumpin air....back into the air. ive kept all the hoses and diverters, and ill keep the pump, its original equipment, but id like it outta there, itsa little bit ugly :hick:
On my 84,302 with smog pump removed the belt length from the crank to alternator pulley is 39 inches, dayco belt # 5060390.When you remove the smog plumbing from the back of the heads plug the hole in each head. They are threaded and will accept a 9/16 x 1 inch course thread bolt. Probably the only place you will get this bolt will be a machine shop-- 50 cents each. Put some sealant on the bolt to prevent leaks.
I used a spark plug broken off and threaded it in:hick:
No I was just saying something that happened to me. The power steering pump froze up and the belt burnt off. So i bypassed the power steering pump with a non A/C belt. I just re-read what i posted and i left out a sentence.:hick: :toilet:
Just for kicks... what kinda psi are we talking about on the smog pump??
not enough to act as a super charger.
I've heard of people using them as superchargers.... on a Briggs
I have a Briggs powered lawn mower...............
haha id love to super/turbo charge a small engine. or just hop it up in general, like shaving the head, porting it or something like that. :hick:
i LOLed when i saw that post though "how much psi are we talking" many people have thought about using the air pump as a supercharger. sure would be sick if it worked though!!!! Kenne Bell would have no business!!!
Change the pully size and you could use it to blow all the leaves and dirt out of the engien bay possibly.
haha it was worth a try, the mentality behind the purpose of a smog pump just stupifies me
Hmmmm.....  This has me thinking.....
If you're running mass air and you ran those hoses into the intake between the air filter and the MAS it might give you a little boost off the line. Not a lot but you might get 5-10 hp. Any thoughts?
i have a 91 ho from a thunderbird.... when i took off the smog pump, with a/c still there, i used a 93inch 6 ribbed serp. belt that i got from advance for $19... everything works great  here's the routing
