Topic: blow off valve??? (Read 5783 times) previous topic - next topic
blow off valve???
can you install a blow off valve on the stock 2.3 setup.  if so how would i go about that!  im very mechanically inclined just not really keen on the turbos yet  but im gettin there!
blow off valve???
Yes you can. Most (if not all) tap into the intercooler. It really depends on your bov as to how you would mount it.
blow off valve???
From what I've read installing a BOV after an air metering device and before the T/B can cause stumbling problems when you go back into throttle.
blow off valve???
I'd just use a BPV (recirculating) on a stock set-up.
blow off valve???
I thought the stumbling/stalling was caused by the bpv/bov staying open.
blow off valve???
Quote from: darkthunder
Think of it this way..
Boost is up
You let off the gas
Bov opens
Air meter is still reading as much air as it was when the throttle was open.
Enough fuel is still being injected for that amount of air.
When you open the throttle again there would be a rich condition caused by this scenario.
Stumble....
blow off valve???
You need to reroute the air coming out of the valve back in somewhere between the turbo and air meter otherwise it creates a momentary rich condition.
blow off valve???
Convert to a blow through VAM...
blow off valve???
I didn't say it wasn't possible to use a BOV on a stock system, but for the way the stock stuff is set up, a BPV works better.
You can use a BOV if you want to deal with the "quirks"
blow off valve???
A stock TC sucks air through the air meter, under the air box into the turbo.
Some guys convert the setup so that the VAM (air meter) is in the charge  pipe going to the intake.
What you can do with that is install a BOV in the charge pipe, but before the vam.  When the BOV opens it will vent the excessive pressure but before the air meter...  so the air meter still reads the correct amount of air going into the engine.
blow off valve???
Quote from: CougarSE
Boost is up
You let off the gas
Bov opens
Stumble....
I get that. All I am saying is that occurs in BPV and BOV setups. Less often in BPV of course, but it occurs none the less. Inferior components and improper setup (not allowing the valve to close) are usually main causes.
After reading numerous topics on the issue, I have concluded that no one is really certain of the momentary rich condition between shifts. It seems to be a myth that gets passed around much like the 8.8 vs. 7.5 weight myth.
Personally I would just ditch the VAM (which is to blame) for a MAF and be done with it but then that wouldn't be stock. :p
blow off valve???
Alright, i have a blow off valve on my car, and i know the Pro's and Con's.
Pro's:
-easier plumbing
-neat sound
-cleaner appearance
Con's:
-Drivability
The momentary rich condition happens wether the car is stock, or if its running a BOV. Thats a myth, but the stumble and stall issues are not a myth. Ive adjusted my driving around those issues, but anyone else who would hop in my car would stall it out once they got into boost.
The biggest issue is that when the air vents, theres nearly enough fuel being shot into the cylinders to momentarily foul the plugs, so if youre in boost, you cant press the clutch and let the car idle, it will immediatly stall. I let off the throttle, and stay in gear for a bit, so that it will clear itself out.
Another issue is starting it. The engine vacume will yank the BOV open since theres not much suction in the intake tubes at that moment, and itll sometimes stumble and stall.
Also, sometimes coming to a stop, itll want to stumble and stall, unless i ride out the gear.
MAF or VAM, the issue will persist, youre still venting metered are, regardless of how its metered. The only way to solve the problem is to run a bypass setup, or convert to blow through.
