Topic: blow off valve??? (Read 5820 times) previous topic - next topic
blow off valve???
Aye sirs, danke for the lesson. :)
Say Shawn, what type of BOV do you have?
blow off valve???
I have the HKS SSQV. I was under the impression that it wouldnt cause the issues it does, so i spent the 220 on it, but the issues are less severe with it.
The REAL reason i went that route is because its one of those most obnoxious ones you can buy ;)
blow off valve???
would a bosch bpv work in my setup shawn? I dont want to have to sell my arm to get one I still need it to shift :hick:
blow off valve???
If you set it up as a bypass valve, it will work very well actually. Its not the *ultimate* solution, but its better than nothing.
blow off valve???
ebay, for a 5.0 mustang
youll probably need to buy a 3" hump hose, and do some tpuppies of one of the tubes though
blow off valve???
Gee, it's not like I didn't mention all that.  :p
If you want to deal with the issues a BOV causes with a metered system, then by all means..go for it.
I had no issues (other than not sounding "cool" ) using a BPV on the metered systems.
On the current SD system in the TBird....by all means ...sure as hell I'm gonna use a BOV......
blow off valve???
What is the benefit to a BOV rather than a BPV?
blow off valve???
BOV's can be less complicated in their installation due to the fact that they just vent to atmosphere.
On a system that is metering air before the BOV, such as a MAF application, when the BOV vents, it vents metered air, thus causing a momentary rich condition, which may or may not pose problems.
On a SD system, the air that is vented is not metered previously, and thus causes no issues.
A BPV recirulates the metered air back into the "system" after the meter, but before the turbo.  They are also usually quieter.
blow off valve???
Are there any performance benefits of a BOV wrt a BPV with an application that vents metered air? It seems they're mostly for show [sound].
blow off valve???
Holy thread resurrection Batman!
blow off valve???
Keeps all the tech in one place...now go tell the man what rear-end he needs!
blow off valve???
Quote from: JeremyB;137193
Nope....
Well maybe in extreme boost situations, but for the normal folks, no.
blow off valve???
ok buys thanks for all the very helpful info...  im oing to install my bailey motorsports twin piston bov in a day or two ill let you know how it goes!!!  thanks again!
blow off valve???
ok so i installed the bov today and so far so good!!  had to adjust the throttle set screw a lil but otherthan that eveythings ok!!!  thanks guys
