Topic: Smog pump (Read 1307 times) previous topic - next topic
Smog pump
Curious if any one can recommend a good smog pump delete kit for an 87 5.0 bird w/part # s etc. If i remove the smog pump is there anything else that would need to be done to ensure everything works as it should.Thanks guys.:D :D
Smog pump
in the general section i have a DIY write up that continues to grow.  You have to select the options on the lower right to make threads in the past year show up.
in my write up, its details how to handle the smog and the vac lines and the belt.  Its a step by step with other goodies as well.
Smog pump
Why are you removing it???
It has been dyno proven woth only 1hp,not worth the 30.00 belt really.
Smog pump
I removed mine because I was replacing the belt anyway, when I put my new alternator in. See here for details.
Smog pump
Quote from: dominator
I was right about 1hp gain at best...you can get a belt significantly less than $30.  That's a heavy little  too...didn't weigh it, but I would think it was at least 15lbs...makes header installs easier also.
Smog pump
Im removing it mostly because it looks like , i just dont think that it will look good with aluminum heads and the other new goodies i have picked up for the bird. Most of the stuff wont being going on untill this winter when i can afford the SDS engine management system to accept the changes in the engine. But because it will be getting headers and exhaust after the upcoming long weekend i might as well have that eyesore and everything that goes with it takin out while i'm at it. Just purely cosmetic!
Smog pump
Well i quess to each his own put,if it works i'd leave it.
Do you have smog police in your area???
Heavy fine if they notice it missing.
Removing all the e-gear that goes with it doesn't do much for hp and will be a pain to remove it all and cap off all of the holes left behind.
Also you'll burn out your cats quicker due to not having fresh air introduced by the pump.
Up to you though,buddy of mine did it all once and regretted it.
Smog pump
Quote from: 4mykid
...untill this winter when i can afford the SDS engine management system to accept the changes in the engine.
I don't understand the reason for buying an SDS engine management system when all you really need is a MAF conversion...and maybe a dynotune...depending on how aggressive you're going to get with it...save yourself the money.
Smog pump
We have NO smog police in Alberta, therefore no cats,no fines to be given,etc,etc. And once again this is purely cosmetic, i think the car will have lots of power with the mods that i am doing so removing the smog equiptment to give me power had NOTHING to do with my choice of removing it all, but thanks!
Smog pump
The SDS system i am purchacing is well worth every penny, they are here in Calgary where i live and I have had the pleasure of seeing it in action on good buddies Mustang. SDS is a much better unit than a MAF setup anyday. Read up on it and you will see why i am choosing to go this route(http://www.wmsracing.com) The only thing stopping me from buying it right now is the wife! She feels the $3500 beans ive spent in the last few months on goodies is enough untill christmas time...Dont want to pi$$ her off as she seems to be OK with this project so far and i would like to keep it that way.
