Topic: My car does have a speed limiter (Read 2509 times) previous topic - next topic
Now that my speedo is off by something like 35 mph I can tell you I do have a speed limiter.  All the symptoms I described the first time around now happen at around 3500 rpm, and I know my valves aren't floating at 3500 rpm.  It is like something is cutting out every other spark plug when I hit what I'm guessing is 85 mph, but the speedo is buried thinking its going 100+.
Maybe it's a 88 thing?
My sister's 88 base with the 5.0L would do the same thing the second it hit 182KM/H (112MPH). You could tell it still had plenty power/speed left when it was at 181 but the second the digital speedo flipped to 182 it was back to idle. If I kept the pedal to the floor it would slow down to, I think, 170-175 and it would cut in again go back up to 182 and then idle back again. It was difinently an electronic thing and not mechanical. I tried to keep it going 180-181 :)
It's a fuel cut-off...didn't I say that before? :D  Just kidding, sounds like it's time to recalibrate that speedo!
Or find away around it!
:D Do I smell something burning! :evilgrin:
dan
1987 Cougar XR7 5.0 SOLD
1992 Ranger 4.0
2018 Hyundai Elantra
2019 Ram Rebel
Quote from: Sick88Tbird
The speedo gear in the tranny is the one out of the 94 mustang, for 2.73 gears.  I had 3.27's, and it was off.  Now with 4.10's I can get that thing into the 90's in second gear.:hick:
When I did my mass air swap in the 88 XR7 I didn't run new wires for the speed sensor, mainly becasue I was lazy. But it cured the problem with the speed limiter. I have heard that you may have stalling problems when doing this but I was luck no problems.
See if you can find a 3.8 pin diagram for the computer there should be a pin marked DSS or something close to that.
When you cut this wire it makes the computer think that the engine is running but the car is not moving.
Quote from: slamedcat
But then my ultra cool tripminder wouldn't work, and we don't want that. ;)
You could put in on a toggle switch for when you want to speed then flip it off to read your tripminder info. you could label it 'turbo boost' :D
Quote from: CougarSE
If you cut the VSS wire at the ECM the tripminder should still work. The tripminder gets its vehicle speed info directly from the VSS sensor (just like the speedo does), not the EEC-IV. The only signal it gets from the EEC-IV is fuel flow, and the fuel flow data would remain correct, VSS signal to the ECM or not.
Just make sure you cut it at the ECM. If you cut it at the VSS itself you'll lose speedo and tripminder functions.
BTW, your tripminder is useless with the speedo being off so far. It may still be teling you your Miles Per Gallon, but it's measuring those miles wrong.
Oh I know, i'm getting 45mpg as it is.  lol I gota get it fixed, then I wont have to worry about no speed limiter as it will be higher (where its supposed to be) than I ever drive.
Just put a switch on the speed sendor input to the EEC... You can label it "FASTER"
Lol
~John~
Too bad you couldn't wire it into the Speed button in the digital cluster :p
Of course your car has a speed limiter. It's called the 3.8! :D:D:D
(I can't believe nobody else said it first!)
Duckin' agents like we was trapped in da matrix!
