Topic: woo-hoo halo headrests!!! now... (Read 3953 times) previous topic - next topic
How do I get my friggin old headrests off!?!?!? I tried yanking em off, no dice. Sticking a screwdriver in there... too round. Shaking em... nothing... sticking the screwdriver back in there... hmmm... it seems to be getting worse. What is the proper procedure here? After years of searching and giving up I finally got my own set of halos and now I can't even get put them in. Interior parts always kick my arse before I end up destroying them. =/
Hizzelp. :D
When I removed the seat skins from the seats in my '96, the headrests were held in with clips. The clips are only accessible when the seat skin is removed (and foam).
Are the Fox seats the same? I have NO idea... but it's worth investigating.
Darkthunder, I could take my pass. side TC seat apart to see, if ya want me to, but if it takes any tools, I'm gonna be up the crick, they're at work, lol...
Quote from: FordTruckFreeek
If you could that would be great. :D Thanks.
you need too slide a flat peice of metal or something down the back of the aluminum thingie behing the headrest into the back of the seat in that little channel.....
~John~
Yeah, you'll have to do as they indicated, and take your upper seat skins off to access the headrest clips, it's not a bad job, either...
BTW, what did ya get your halo headrests from?
I got a set of seat from my escort GT, that I'm gonna pull out of my mud truck, and put away.(while their still clean)
when i did mine i used a hacksaw blade  it was flat enough to slide in and release the clip..  on the backside of the headrest.!!!!!!!!!1
I think MDJ1281 removed his some time ago too.
At the bottom of the headrest shaft (front side) there is a horizontal groove to which a spring loaded tab recesses into. By sliding a Slim Jim  (or hacksaw blade) down the "front" of the headrest (headrest all the way up) at this point the tool being used will bottom out. Push down with alittle more pressure while slowly pushing the headrest down 2"-3", this will force the blade past the tab....at this point while holding the blade in place the headrest will pull right out.
And if you rip off the fabric, it looks a little something like...
Quote from: thundergrowl
Wow, that worked to perfection. Thanks thundergrowl and masterblaster and everybodies. :D
Picture?
trade you the 3G for those ;)
~John~
Picture?
It'll be monday before I can get any pics, I'm in AL right now.
Quote from: shame302
although tempting, i searched too long for these bad boys. :D
it...worth a try....why the heck are they so hard to find anyway...didnt quite a few escorts mustangs and capris have them?
~John~
