Topic: 1986 capri RS * now with pics* huge pics sorry (Read 3599 times) previous topic - next topic
wtf ... why cant i post pics ... it ....< kicks computer>
Z
hunting for another 87-88 bird
If it's got tits or tires its gunna cost you money !
http://www.foxtbirdcougarforums.com/showthread.php?t=3105
thanks i read that before . it uploads the pics then just stops ,must be my dail up . i put them on a disk  and will up load it at school when i get a chance.
Z
It could be all gummed up.  Gas turns to varnish, and after 3 years you could have all kinds of sticky goop.  Are you getting power to the pump?
The FP or EEC power relays could be sticking as well.
Gas is new as of a month or 2 ago . As for the pump geting power all I know is its not kicking on when the car is being started . Relays i was just talking to my dad and he asked one of the mustang guys where he works and they said one of the relays is under the drivers seat . Anyone know how many relays there are ?
Z
The gas in the tank may be new, but all the old gas in the lines, pump, filter, injectors is not.......
ah true enough .... i think as long as its nice or warm at least  this weekend . we will be riping,tearing,testing,checking,swearing and spending money at NAPA . so if a relay is under the drivers seat dose that mean under the carpet usually ?
Z
Quote from: hundred_dollar_5.0_t-bird
Z
No...it will be above the carpet.  Brown is ECU Power and Green is FP
ahh .... i was going to go on saturday and start ripin the interior apart:dunce: good thing i asked .
Z
I wouldn't really worry about the old gas part.  I bought a '70 Tbird that sat in a barn for 12 years with a full tank, started with some ether and ran like shiznit, but still ran enough to drain the tank eventually.  Granted a carb and injectors are different, but fuel probably isn't a concern.
One more thing,  if you find out you are getting power to the pump, but have no pressure in the line, the line inside the tank between the pump and sending unit is gone.  I've had this happen two times.
first try the starting fluid. 8 fuel injectors will clog up alot faster then two or three carbjets. also alot more kinks in the gas lines.
I am just saying, if you arent sure if the fuel pump is kicking, use starting fluid. That will tell for sure it is a problem with the gas. It saves time and money.
i know  the fuel pump isnt kicking on because i had my head right under the tank whem my dad went to fire it up . gotta check the relays and find out if the pump its self is bad
Z
I had to replace the tank and pump on my nephews '87 Stang that had set for 4-5 years. Pump(and tank) was ruined by the gunk, goop, and rust in the bottom of the tank. Got lucky and found a nice one for $25 at a swap meet...
pics ... uh no no
Close this window Manage Attachments
Upload Errors
Imag0002.jpg:
Upload of file failed.
Imag0009.jpg:
Your file of 441.7 KB bytes exceeds the forum's limit of 146.5 KB for this filetype.
Imag0010.jpg:
Your file of 459.8 KB bytes exceeds the forum's limit of 146.5 KB for this filetype.
? it wont work
help me please ... what can i do to make them smaller ... im at school right now  so internet is pretty fast ....the pics are on a disk
Z
this car only had the front end repainted after an accedent(sp?)
drivers rear fender lip from the bottom
just in front of the drivers rear tire looking towars the front
front end
over all pic
interior
engine
sorry for the py photograph im a amature and the wait
Z
