Topic: engine computer question (Read 1062 times) previous topic - next topic
Can anyone tell me what the part number is for an engine computer to a 5.0L speed density SEFI setup?
Thanks
Dan
87 T-bird two tone diarrhea color. 5.0 converted with AOD.  GONE BUT NOT FORGOTTEN
94 Lincoln Towncar, Dark Metallic Green, 4.6L AOD
SOLD!!!!
99 Mercury Cougar. V6 MTX75 Trans. CURRENT PROJECT DAILY DRIVER.
Look at http://www.fordfuelinjection.com under EEC program codes. You'll find the code #'s that show on the upper right hand corner of the computer harness connector. This page includes 5.0L SD computers for HO mustangs, Lincoln MkVII, TBirds, etc... Hope this helps.
87 Sport with HO cam, 19# injectors,TB+Upper Intake,87 Mustang EEC, Cloyes double roller timing chain, Kirban adj. fuel regulator and Autometer fuel pres. guage, HO shorty headers + LSC H-pipe and Dynomax Super Turbo lers, Ford Racing 9mm wires, K&N filter / no air resonator, 8.8 XR7 Diff., V rated tires, Project ongoing.
oh wow thanks that pretty much tells me what I need to knowas well as some other stuff I was wondering that Im not anymore
SOLD!!!!
You need one?
It's Gumby's fault.
I found one on ebay. That's what I needed the number for. Had to save the pic, enlarge it enormously, and then piece together the dots from being pixelated to come up with the number on the piece they were selling. But it turned out to be a computer for an 88 Tbird 5.0 speed density set up. Just what I needed to get it working.
Now if I can come up with a wiring harness I got it set. That's the last piece I need to complete my 5.0 transplant other then the exhaust which I may have worked out with another forum member.
  I found the intake, throttle body, EGR spacer with valve in working condition, fuel rails with injectors and injector harness, a cold air intake,and the computer all for around 100 bucks. Not bad considering its the HO Intake, throttle body, and spacer.
That along with the E7 heads off the 302 out of the truck I ran across should beef the motor up descent I hope.
  Hopefully soon I can post pics of my bird with a 5.0 in it, as well as maybe a few before after and during pics, since we've documented everything thats been changed so far.
SOLD!!!!
Find yourself an HO cam, and some 19% injectors, and i have an HO speed density EEC id sell ya relatively cheap.
It's Gumby's fault.
ditto dude...wish i knew you needed all that. could have one stop shopped with me ;) i have all the HO stuff as well as all the factory tbird 5.0 SO stuff minus the harness.
~John~
well thats just it I didn't actually need it all. I was actually just looking for a SD computer ran across all that other stuff for an HO and decided hell with it. I have the injectors already theyre on their way I just dont have the cam
SOLD!!!!
