Topic: inner fender mod (Read 5220 times) previous topic - next topic
inner fender mod
Here's my idea...take sheetmetal and following the lines from the strut towers form a cover for everything on the sides...makes them even, and cleans stuff up...I'm going for it...what's to loose
inner fender mod
i for see an issue. how would you change your wiper motor when it does go bad? also the battery and everyhing on the firewall and fenderwells is that just gonna be covered and acsess panels made to get into there to change or repair also what bout our air box? soo mutch can go wrong with something like tat bur also i think e-man did something like tha with the converdable.
Got that fox rash again!
-Resident smartass! :ies:
inner fender mod
well, how are you going to attach them?  Dzus fasteners?
Also, Im curious about how you are going to form the panels - Do you have a small sheetmetal brake or something like that?
inner fender mod
the pics don't do justice,and I suck @ computer imaging...the motor will be exposed...the panel's are able to be removed. firewall will be exposed...it's gonna be carbbed so no airbox...
inner fender mod
Quote from: 302Fairmont
yes I got a sheetmetal brake...my bro works for a local steel company...they will probably bolt on unless I find something else to use that'd come off quicker
inner fender mod
Personally, I think it's a great idea.  Along with most great ideas, they've only got great results with a decent implementation.  It's your car man, go for it. If it turns out decent, I may steal the idea.
inner fender mod
Quote from: 86Tbuzzard
Dzus fasteners?
inner fender mod
Cool.  Im trying to google some pictures because I know I've seen other cars with panels like you are talking about - but nothing is turning up.  I've seen it alot on mini trucks/ lowriders.
inner fender mod
I like the idea as well. I've actually seen someting similar on a Mustang, only difference was that it covered the radiator core support and such. I think it was an aftermarket production piece, and i've only ever seen one.
inner fender mod
I was thinking of doing the same thing except on a smaller scale.  I was just going to cover up the coil and wires around it, but that's all that I have over there anyways.  Just something to clean up a messy spot.  My only concern was how to make it look like it wasn't a piece of sheet metal just stuck on there.  I don't want it to look tacky.  Post some pics when you do it, I am curious how it will look.
inner fender mod
Yuck!
That demonstrates the next concern I had. Where do you start and stop the cover up?
inner fender mod
that's hidious! I like the idea of just evening the sides out while covering up the ugly "bullet" holes in the frame.
inner fender mod
Has anyone ever thought of just hiding all the engine compartment wiring in the dash(almost done) and putting the battery in the trunk(i've already done that) smoothing and boxing in the engine compartment frame rails(working on it) and filling in the swisscheese holes? I got inspired my a few cars I've seen in my mustangs and fast fords magazines. I'll have pics of my progress sooner or later..
~1988 thunderbird~
In hibernation, waiting for spring.
inner fender mod
Hey I never said I liked it.  I was just showing him something similar that someone else had done.  Personaly his whole car is not my style if any of you guys have seen it, but I'll give him props for doing it up right and actually doing the majority of the work himself.
