Topic: o-rings (Read 1782 times) previous topic - next topic
o-rings
hi guys,hope your holidays are going good. i need some help on o-rings for my fuel injectors. i called ford and they said they are not available. only way to get them is to buy a fuel injector..lol..i have new injectors in my 86 cougar with the 3.8 engine. i suspect one o-ring may be crimped from improper installation..i have too much gas going into the throttle body...making a little rough on the idle. so my question is ...does anyone know where to purchase 0-rings for these cats? i appreciate any help...thanks in advance
o-rings
if you cant find the right ones from Ford, maybe find out what the o rings are made of (nitrile i think) and match them up at the hardware store or a tool supply house like J&L Industrial Tools
o-rings
NAPA should have "kits" as should most good parts stores.
You used to be able to buy packets of o-rings at Motorcraft dealers too.
o-rings
i did call napa and they said no deal....i did'nt ask them about any kits. but i will call them in the morning and ask.
o-rings
Auto zone carries them in stock here there like 9.00 for all of them
o-rings
kool. ok, on the injector note, on my 4 banger i can not get the injectorS to stop leaking ! :mad:  i have new o rings and have ajusted the rail several times. is there a trick or are the famous for doin this? should i just get a new/diffrent rail? thanks :locked: - that looked funny, thought  i would use it
o-rings
It's possible the injector bodies themselves are leaking.  It happens.
You might need to swap injectors.
o-rings
make sure you use wd40 to seet the injectors. i've torn injector 0 rings just craming them in there.
o-rings
get me the number off the side of your injector and Ill get ya the rebuild kits, I work at NAPA, and I do the check/flow/cleaning of the injectors there....
o-rings
ok thanks, i would like to get another intake anyway, so i will just get it with rails . thank goodness for the junkyard with cars where they shouldnt be ;)
o-rings
thanks bogus...the number on the side is d1820ba..thanks for your help
o-rings
-what's up with some of these moron parts people out there.  seems like they must be rich and dont need any money.  i like to sell parts myself.  my kids like to eat. so do i.  the ford part# is fopz-9229-a, or motorcraft part#cm4717.  this pack has a total of 10 o rings in it....:screwy:
hope this helps....
stu
o-rings
thanks shorangerbird..i'll call tomorrow and see if anyone has them.
o-rings
update....the mercury dealer will have the o-rings for me on wednesday...using the part number from shorangerbird...thanks again for all the help.
