Topic: Looks like I'm getting a truck.. (Read 1101 times) previous topic - next topic
You'd think I'd be happy to finally be getting something I need, but not with the cirspoogestances of getting this. (getting it because my grandfather's almost gone, and I'm getting my uncle's truck when he gets my grandfather's F150) But anyway, looks like I'm going to have a Dodge full-size regular cab truck, in the style that came just before the recent one. (late 80s/1990-ish)
Have to put an oil pan gasket on it and both valve cover gaskets.. is the former as much of a pain in the ass with a 318 in a Dodge truck as it is on one of these Fox bodies?
Feel free to get all those "Eww, a Dodge" comments out of your system now.. :p
EDIT: The following isn't a picture of the truck in question, but it's as close as I could find to it in a quick search. Same color, same body, I think:
Not sure if this is the correct years or not....
http://autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/10/18/5a/0900823d8010185a.jsp
5.2L and 5.9L Engine
See Figure 7
Disconnect the negative battery cable.
Remove the oil dipstick.
Raise and support the front end on jackstands.
Drain the oil.
Fig. 7: Always install a new oil pan gasket on a clean surface-V8 engine shown
Remove the exhaust cross-over pipe.
Remove the left engine-to-transmission strut.
Remove the bolts and lower the oil pan.
Thoroughly clean the gasket mating surfaces.
When installing the pan, always use new gaskets coated with sealer. Apply a drop of RTV silicone sealer where the cork and rubber gaskets meet. On the 5.9L engine, make sure the gasket notches are positioned as shown. Tighten the oil pan bolts to 15 ft. lbs. (20 Nm). Tighten the cross-over pipe to 24 ft. lbs. (32 Nm).
Sounds straightforward enough.
Who was it awhile back that had to mess with their oil pan and ended up having to take it to a shop or something? I'm hoping it's not nearly such a pain in the ass on this thing.
[SIZE="7"][COLOR="Red"]"Eww, a Dodge"[/COLOR][/SIZE]
:yuck: :2gunsfiri :flame: :barf:
Quote from: Bird351
That would be me. I think as long as you don't a have K-member going in between 2 sumps to contend with you should be fine. Also when you torque down the bolts, make sure you triple check the setting on the torque wrench. Then have someone else check it, trust me ;) !
