Topic: Rims (Read 3242 times) previous topic - next topic
Rims
Guys i have an 85 t-bird looking a pruchasing new rims can you post some pics of the 83-88 bird or cat with aftermarket rims and rim manufacturer and type.  Thanks in advance for your posts
Rims
My 88 Cougar.:banana:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Rims
whoops wrong ptc, duh.:brick:
Rims
87 turbo coupe with black 93 cobra replicas 255 45 17 tires
they are actually forsale
Rims
95-96 Cobra Wheels
Rims
FR 500, 18x9.:D
Rims
Quote from: darkthunder
95-96 Cobra Wheels
i really like how those wheels look. i want to swap to 5 lug but that means i cant keep my 93s :-(
Rims
ME too... wish I never sold them. I like your wheels, I'd take them off your hands if I had the money.
Rims
All 3 of my setups:
1st: ROH ZR's (17x8.5's w 275/40-17's)
2nd: FRPP Cobra R's (17x9's with 255/45 and 275/40-17's)
Current set up:
Custom made, 3 piece IForged "Aero"
18x9 w/255/40-18's up front
18x10 w/295/35-18's out back
Rims
Not sure if any of you guys are interested, but Latemodel Restoration Supply has an ad in 5.0 Magazine that says they have '93 cobra replicas "starting at $590 a set" in satin, black, anthracite and chrome. Doesn't say if they come with center caps or not, but I sure wouldn't mind having a set of those in anthracite...
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Rims
Quote from: The Hawk
All 3 of my setups:
/QUOTE]
did u have to mod anything to fit the 275 40s all the way around?
Rims
Quote from: Turbo Coupe
All 3 of my setups:
/QUOTE]
i
btw you can put a 17x10.5 wide wheel under the rear with 315/35/17's  with no clearance issues if you remove the quad shocks.
Rims
On the rear no......the only reason I could get away with 275's up front was thanks to my track alignement settings (-2.5 degrees) With a normal street alignment there's no way in hell it will fit....255's tops.
Quote from: SLEEPER T-BIRD 87
No you can't. Maybe a set of Nitto drag radial 315's (because they're no wider than a 295) but there's no way you're gonna fit a normal sized 315 in there. I did tons of measuring to see if there was any way it could work....and the bottom line is the wheelwells just aren't deep enough. With my setup now there's only 3/4" of clearance between the sidewall and inner wheelwell and the quads are gone as well....gotta leave room for movement if you plan to go around corners at all and 3/4" is considered the minimum.
Rims
i have pictures to prove that they fit  they were spoogeho 710's
check out my thread in members rides .belive there on the second page.
stock width t/c rear  stock wheel wells  s95 offset wheels (cobra r's)
and ran 275/40's on the front on 17x9's
Rims
It's hard to tell anything from those pics other than the fact the fronts clearly stick out past the fender and those rears look awful skinny for a 315. I'm not saying they're not 315's...obviously you can read if that's what's on the sidewall, just that they look thin compared to 315's made by BFG, Goodyear, etc. My 295's look bigger IMO
 I should also mention....when I make the declaration that a 315 won't fit....I'm basing that on a lowered T-Bird. If the car is at stock height like your's is, virtually anything will "fit" without hitting. Try fitting 315's on a lowered Bird....it ain't happening.....295 is as big as it gets while keeping the sidewall inside the fenderlip without hitting and avoiding rubbing the inner fenderwell.
