Topic: Broke Down and Did It (Read 1404 times) previous topic - next topic
For the past two weeks or so I had noticed hust a hint of blue smoke on startup coming from the exhaust.  The bottom end of the motor has 30K on it and holds good oil pressure.  The heads are mild ported e7's and the valve guides are worn so I'm doin the nasty.....
http://store.summitracing.com/default.asp?target=partdetail.asp&Ntt=Trick+Flow&N=1011&part=TFS%2DK514%2D350%2D370&autoview=sku&Ntk=KeywordSearch
http://store.summitracing.com/default.asp?target=partdetail.asp&autofilter=1&Ntt=Ford+mass+air+conversion&N=0&part=FMS%2DM%2D9000%2DB50&autoview=sku&Ntk=KeywordSearch
Wish me luck!
Re: Broke Down and Did It
Getting the Ford mass air kit instead of picking your own parts huh?
Nice TFS kit too.
Big Spender  :giggle:
Wow all the components are there. It will be a piece of cake to install. Have fun! :D
you suck! :D j/k, all i want is my car to run again. i should of never torn it apart. :( congrats and good lucks. i'd love to help you if i could. *nod*
I'll be parts hunting.  Gonna grab some 24 pounders and a larger mass air meter from a friend of mine.
yeah..youd be nuts to spend 550 beans on a maf conversion...IMHO anyways
let us know how it goes. id love to see what it nets....
~John~
Quote from: shame302
Yea I'd get one of the conversion harnesses from ebay and a Mass Air EEC ain't that hard to find... Then with your buddies injectors and air meter you'd be set.
i'm jealous.
Man finally hit 12's in the cougar?
Probably real low 13's, maybe 12's with the right convertor.  I just wanted to finallly get it all done at once now that I have an excuse.
what size meter comes with that FMS kit? 55 like stock?
I believe I am going to order that kit myself ,see if I can waken my motor up a little more with the combo I have.
Good luck and let us know how your conversion goes!
