Topic: 351 go Boom (Read 2122 times) previous topic - next topic
351 go Boom
I had a slight piston failur the 2 days b4 going to the track.
car started to smoke a little and we thought it had intake gasket gone. We found that the #6 plug was getting oil on it.
Had probs br4 with intake gasket so thought the same.
In the time it took to drive to my buddys shop the little smoke went from just a little puff to Oh shiznit. Did compreson check and all was good. So still thinking it was intake we yanked the intake off.
Nope it was good. Off came the head and nope head gasket was good. So pulled the motor.
Found Oil ring and the full side skirt of the piston in the oil pan.
Forged piston to top it off.
Oh well
Re: 351 go Boom
yikes.. way NOT good. at least you have an excuse to make more power.
"i had to bore it over, and I couldn't trust those heads after that"
Re: 351 go Boom
yeah sorry to hear about that man. Give u s some pics?
Re: 351 go Boom
My Buddy is sopose to put up a small page for are hobby shop and a few of are cars.
The block was already 30 over and lucky as it sounds i can get away with a slight hone and callit good.  Will stuff one piston back in it with new rings and try and get it back together as soon as we can.
If u want pics of the 85T or pics vids of my 83Cougar i have losts
Sirchirpalot@hotmail.com
Re: 351 go Boom
Sorry to hear that I had a 351w in my cougar also after spending like 2 1/2 grand to get it running it only lasted like 3 weeks and piston 7 exploded.
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Re: 351 go Boom
Well my motor had a bit more then that into it.
Cost for stuff in canada sucks Ass,
Roller lifters alone cost 750 plus Tax's 15%
pistons were 900
rings alone were 325 for hellfires
Roller rockers are 340
Should i go on?
750 demon carb sells for 700
MSN box 250 Billit dis 3something i forget now.
still have block Stock,
Crank is stock with crower rods.
ARP everything Studded the mains heads intake
U name it if ARB makes it and i need it i have it LOL
ARP also makes Oil pump shafts too.
Re: 351 go Boom
Here is a few pics of my motor as i took it apart
#1 shows the how the motor looked as i took it apart,
U can all see i have some good stuff in there too.
#2 shows how bad the oil got was in the head.
#3 lets you see the dif between number 5 and 6 pistons how can we tell witch one got the oil.
Re: 351 go Boom
well the car is back together again
Re: 351 go Boom
Just repl the one piston???
Re: 351 go Boom
no i replaced all 8 and did a hone new rings and bearings.
Found 1 other piston with a cracked skirt so said hell with this all new ones.
I cleaned up the rods and crank new bearings new oil pump and chain.
I also got the ARP oil pump drive shaft and put that in there.
I have 300Kms on the motor now so still babying it a bit.
Key word Abit LOL it pulls nice up to 4gs havent pushed it past yet
Re: 351 go Boom
What?  No buildup pics?
Re: 351 go Boom
yah. come on. you know we are pic junkies...
Re: 351 go Boom
well i been bugging my buddy to set a page up on his server,
I also want the 91mgs of racing at the track posted,
