Topic: Subframe connectors (Read 9260 times) previous topic - next topic
Subframe connectors
Can you guys provide some pictures of your sub-frame connectors ?
I can't decide on what route to take with mine.
I plan on going extreme with these things so I want some ideas.
At this point I'm thinking of buying the Global West pieces and adding additional support at the front and rear.  Pics installed please.
http://www.summitracing.com/parts/gls-918/media/images/year/1987/make/ford/model/thunderbird
Maybe I'm wrong but  I noticed a member by the name "Aerocoupe" seems to have roll bar tubing subframe connectors that tie into the trunk frame. I like that idea.
Subframe connectors
I made some based off of the global west connectors. I think for a street car these will do fine. If you are building an all out drag car or you want the stiffest chassis possible you may want to look at the thru the floor connectors.
Subframe connectors
I've just got 1"x2" square wall tubing as subframe connectors. It made the car noticeably more solid over bumps. It also corners much better as well.
Subframe connectors
thunderjet302,
 Can we see the rear section ?
I'm curious if you welded on the angle part of the torque box/jack plate area or directly on top of it.
 One of the main reasons I'm interested in subframe connectors is the fact my car spends so much time on a lift (lol).
Subframe connectors
Take a really good look through Jerrys (Daminic) thread "project evolution" he want all out. Jacking bars, seat braces, sfc's the whole nine yards
Subframe connectors
I want to brace the front frame rail some how.
Here is a pic from Project Evolution thread that shows my area of interest.
Another idea for the rear is to make a horizontal brace.  From torque box to  torque box.
X
Subframe connectors
Braced like that?
Thread below:
http://www.theturboforums.com/threads/319499-93-COBRA-BUILD-%281000HP-GOAL-TT-5-4L-DOHC-345-30-18-s-Custom-IFS%29
88 Turbocoupe: Coast High Performance 331 kit 28oz balance, Comp XE264HR14 cam, 58cc 185 afr heads, 1.7 roller rockers, Mass-Flo EFI (was POS to setup and their techline is a joke at best)
Full 1 5/8 primary equal length headers, 2 1/2 exhaust, Full manual reverse VB c4 and baked off clear coat "BECAUSE RACECAR"
Subframe connectors
Subframe connectors
Quote from: 2tbirds;411788
Here is the car on the outer 1" tubing.
The gaps around the door didn't change
Subframe connectors
daminc,
 you are awesome sir.
Subframe connectors
Awesome design Daminc. How often do you get to see a Unibody car jacked up from the side like that so easily, lol.
You fab that yourself?
Subframe connectors
That's some nice stuff
Subframe connectors
Quote from: Big B;411906
Yes, I made just about everything that went into my car, including the new front frame sections
Subframe connectors
Soul,
 That pic is hot too.  Is that your car ?
 How does one get thick tubing bent like that Rack & Pinion Cross Member ?
Or is this a pre-formed piece ?
Subframe connectors
If you jack it up just right I had 3 wheels up on mine.
