Topic: haha i passed emissions somehow... (Read 2423 times) previous topic - next topic
pulled up and the guy put "unsafe" into the computer, said with it being a c4 and ratchet shifter they cant treadmill it, so from now on i get the idle test :D
still surprised considering it needs a tune up (original wires and everything, no smog and cats might be dieing)
Re: haha i passed emissions somehow...
my car passed with motorcraft wires that said 1986 on them. That was before the black exhust thingy though.
yeh my wires still say 1988, went to carlisle to get tuneup stuff also for cheap, came back with taillights and a hood lol
heres my numbers...
HC
state-220ppm
me-176ppm
CO
state-1.20
me-1.18
co2
state-6.0
me-13.31 (and passed lol)
Tampering Inspection
Gas Cap-pass
Catalytic Converter-N/A (lol)
You Suck :flip:
I can't pass to save my @$$
eh, passing is over-rated, it's all about the R!!!
Fred, i might have a connection on a stock h-pipe for ya
Quote from: Tbird232ci
Reeeeallllyyyyy. With cats and all? Wouldn't be bad if I could swap that thing on to get me through the test and whatnot. Details! I need details! :D
Quote from: 5.0willgo
if i can get ahold of my buddy, and tell him to hold one, itll be yours
Lucky dog, ,,
There's a reason for me to learn to drive stick  - to avoid the treadmill test.  My new 5.0 HO transplant just failed NOx on treadmill.  I'm hoping its due to an overheating problem that I've just discovered.
You don't have NOx levels listed, they don't measure that when its tail pipe only?  The state limit for CO2 on treadmill is listed as NA, so that apparently isn't a law YET!
V6->V8HO 88 LS
5.0L V8 87 XR7
Quote from: bondocougar
What! That's ridiculous. Maybe time for an H-pipe (squeeze one more cat in there)? Or maybe just "accidentally" have some exhaust leaks...  :evilgrin:
1984 Cougar Convertible
1988 Cougar XR-7
his is a 3speed auto
theyll test a stick, 90% of the time, they smoke the clutch too
bondocougar: just put a full manual valve body in there with a ratchet shifter and ull get the idle test :)
NOx was N/A I believe ill look again when i get home.
What is this "emissions test" you all speak of?  The concept is alien to me.  :D
-Jim
1987 Cougar LS 5.0
Thanks Shawn  :D
That's typical. Mine failed after my transplant as well. I hope you atleast got a two year extension since your emissions equipment is new.
