Topic: You need subframe connectors (Read 17437 times) previous topic - next topic
Quote from: Cad-T-Bird 500;357181
Thanks for the pictures.  Maybe you don't need the flat plate on the side but I think it makes it a bit stronger.
TED
I had the plates. The guy who welded them on (he builds cages and such for race cars) said that I didn't need them. He said they really don't add any strength over just welding them on.
Quote from: BlackBird88;357182
are the sub frame connectors t-bird specific? will a set of maximum motorsport xl full length for mustang fit?
Yes and no. The Mustang has a bend in the floor pan the T-bird doesn't. Mustang subframe connectors are bent down where as T-bird ones are flat. You have to bend the Mustang one flat to use them on a T-bird.
Those do look a lot easier than I thought. One of these days I'll have to have some welded in. I assume it would be safe to use the connectors as a jacking point?
2002 Honda Civic EX
1984 Ford Thunderbird Elan
5.0 CFI, T5, Dual Exhaust
Quote from: thewestie;357186
That looks easier than I thought. I was looking at a through the floor set up I might go that route. Anyone have pics of through the floor subframes?
Now Ill be a pain in the ass. Do you have a pic at the rear subframe at where it goes through the floor?
Now those are real sub-frame connectors and overkill in my opinion.  Would be better for road racing than drag racing, and what you need if you plan to cut off the top.  Also great for side impact from a low rider.
I would think the Mustang would not work at all, the Mustang frame looks completely different and overall shorter.
TED
Someday Id like to road race in something like a street GT class as well as a trip to the strip. I'm 6'6" 300 lbs. I don't want to go much below 11.49 If the car needs monkey bars Ill never fit I look funny getting in and out now.
:punchballs:
Quote from: thewestie;357205
something like this? or a diff angle?
I made them that way because of the rust.... that, and I've been known to get a little airborne before. I also like to take turns at at least 55 60 mph..
That gives me a better idea. Ill go stare at the underside of the car some more tomorrow. Maybe take a nap wile looking at  it. I need  new fuel lines and I put the battery in the trunk and need to run some wires so Ive got some thinking to do under there. Really wish I had a lift.
Quote from: daminc;357214
So I got a 12' piece of 2"x2" 1/8" stock Iv got the fuel lines and brake line out of the way getting read to cut it to 5' 6" and make the front cut. I cant tell from the pics how far back on the rear subframe you went or how high you went on the floor pan? any more pics would be great.
Thanks Steve
Quote from: thewestie;357293
Thanks Steve
I will find more for you tonight.... hold tight, I have over 3000 pics of the car now....lol
Thanks The car is more apart than ever. I'm gonna use the drawing you gave me awhile ago. and start from there
oh yea, I forgot about that.... give me a couple hrs
