Topic: a new beater (Read 2698 times) previous topic - next topic
a new beater
Should be a fun project...  1993 Thunderbird SC...  Wish it had the M5R2, but the AOD will do I guess...
I just set the scoop on for now, it isnt bolted down...
Only issue, (aside from needing a major clean and detail) is it needs a major tune up as it stumbles, and misfires, when you get in the boost.  As you can see in the engine bay shot, it looks like the #5 wire is/was arching out on something...  Going to get new wires and plugs today for it.  engine and tranny were just rebuilt 20kms ago.
I did the plugs last night but waiting on the wires to come in later today...  pretty bad when you have to change plugs from underneath LOL.
a new beater
Nice looking car.......like you said, just needs a good cleaning!
88 sport,TW heads, comp xe270hr, cobra u/Tmoss ported lower, 65 mm throttle body, under drives,smog delete,
1.7 roller rockers, cai, k&n, bbk adj regulator, 76mm Pro-m,all MSD ign. MSD dist,18° base timing, 3g alt.1 5/8 ceramic headers, 255lph walbro, 2.5" h-pipe, flowmasters, silverfox valvebody, 3.73 gear,
http://i216.photobucket.com/albums/cc154/flipnbird/DSCF0185.jpg ( RIP : ( )
a new beater
I miss my coupe.  Put my Cat and Jetta to shame by the way it handled.
a new beater
Not a bad winter beater at all!  The AOD is definitely easier to drive daily.  I hope it works out for you.  I'd say a better winter beater would be that Dodge Spirit your neighbor has. :)
a new beater
Quote from: 1WLD BRD;341797
I found copper plugs worked best. Any platinum plug except the Motocrafts are guna be trouble.  I would also stick to motocraft wires.  I had problems when I kept blowing out the spark (I had a 15% overdrive on mine) until I put the copper plugs in and undergapped them.
P.S. a stubby ratchet makes changing the plugs a load easer and use lots of anti-seize.
There is something weird about your coupe too.  It should have a TEVES hydroboost master cylinder, but clearly someone has swapped it over to conventional vac assist.  I would speculate you no longer have ABS.
a new beater
I noticed that too. At least looks like it was done right. IMHO I would rather have conventional vac. assist, non - ABS brakes in my Mark over the Teves system. Easier troubleshooting and a lot less problems.
Sweet car too. Those are about the only car I like in the color Red. Nice score.
FOXLESS!!
1994 Lincoln Mark VIII
a new beater
Looks nice , I havent driven one of those since around 1990 , but I remember it being fun
a new beater
Quote from: The Shredder;341818
Agreed, my gf's dodge shadow was basically the same car and was unstoppable through feet of snow with the right tires.
a new beater
The tires on it are so tiny. I'm surprised at the lack of rust.
a new beater
Burn them tires!!!! I love that supercharger sound OH and the smoke!!!!!HEHEHE
1987 T-bird SportCoupe,302,5spd,8.8,3.27s,pbr brakes,spindles,2003 rear,18inch 06 gt rims!!!!:evilgrin:
2006 Gt Mustang,3v,5spd,8.8,3.55s,GT500rims.
1990 T-bird LX,3.8,aod,loaded,stock!!
1999 Trailblazer(wifes rig)
a new beater
I really need to change the plugs in my 89.  Should I be worried about pulling the threads out of the head since I'm sure they havent been out of there since 89 (61000 miles).
PS - these cars DO really respond with mods.  Full exhaust, CAI(you have the same ebay one I got), and a pulley.  Did the pulley tonite and it'll roast the tires from a roll now!
a new beater
that scoop is horrendous.. i love the 89-90 XR7 wheels though.. if you want a nice aftermarket hood, the mach 1 hoods look great on SC's.. i'm jealous though, i want another 1
a new beater
Quote from:  There is something weird about your coupe too.  It should have a TEVES hydroboost master cylinder, but clearly someone has swapped it over to conventional vac assist.  I would speculate you no longer have ABS.[/QUOTE
93 was the first year for the third gen Teves system. They didn't look like the first and second gen systems were used to.
a new beater
I couldnt bring myself to use that as a winter beater(of course I am a tad biased toward t birds). Does it have hidden issues? as it looks pretty nice in the pics. I guess I wont feel as bad now if I drive my XR7 all year
