Topic: For those who may have missed it..... (Read 3125 times) previous topic - next topic
Two weeks ago this coming Thursday,I was installing sound deadener in the Sport. I started with the roof, then went to the trunk, and I had stopped for the evening. I was moving the Thunderbird from the drive way when I happened to notice that my clock and radio weren't working. I though to myself " a blown fuse". So, I pulled back into the driveway and got out. I looked up at the fuse panel,and I saw a large burnt hole with a white ashy center. The hole was about the size of a 50 cent piece. I tried to drop the fuse panel, but the wires were to short and tight to allow it to drop, so, I removed the dash and this is what I found upon more inspection............
I remembered that the '86 V-6 Thunderbird was at my favorite boneyard (only Bird for miles). I had gotten the dash from it a few weeks ago. Anyway, I drove the 16 miles, and cut out the fuse box leaving about 6 inches of wires on them. I got home,and compare every single wire from the Sport ('88 5.0 car) to the '86 fuse panel....identical to the last wire.... WOO-HOO !!! (looking for anything positive at this point). I then started swapping the fuse panel one wire at a time. Cut and graft.....cut and graft....cut and graft.... until it was all done.
After I finished swapping the panel, I figure now was a good time to install the rest of the sound deadener throughout the floor,firewall,and doors. While I had the carpet up,I found wires on the passenger side and driver side floor running along the door jambs that were melted. i replaced those and finished up. I took the replacement dash and dyed it gray, along with the console, glove box door and associated dash pieces. I installed the passenger side power seat equipment that had been in the garage since early this year as well. I applied sound deadener on the back of the dash and air ducting as well (had an extra roll....Thanks Zillamat !!!).
I then installed the dash, console, and everything else. I turned the key on and no dome light, no radio, no clock, no trunk light.I checked the fuse, burnt out. I installed another,and still nothing. I got to trouble shooting again, and found the dome light harness that goes down the passenger side a-pillar was melted. back to the salvage yard,pulled the dome light harness and installed it. Same issues, no power still to those above mentioned items.
I called Jerry (daminc) and we talked for a while and did some long distance, over the phone trouble shooting and I found that the visor harness was bad. It had a screw from the driver side visor going through it. Grounded out. I swapped that harness and everything worked as it should.
I went out to move the Sport last Thursday night, one week after the whole bunch of  started, and the dash lights and head lights didn't work,but everything else did. I swapped the light switch, no change. I pulled the switch again,and looked at the fuse harness with a flash light and there it was.... a wire had broke from it's connection. I reconnected it together and then everything was working perfectly again. What a relief.....for an hour.
I went to pick my son up from school and it was pretty warm,so,I figure "I'll use that a/c I paid all of the money to have working again". No cold air. I called the a/c guys at "Olde and New", and they took the Sport yesterday and changed a bad valve for the R134 conversion and now, really cold air, and all is good again. 46 hours of total labor. I can NOT imagine having to pay someone to do all of that. Holy .
And that's what some of you missed during the forum's hiatus.
dots?
Quote from: sarjxxx;340239
dots?
what does that mean?
Quote from: vinnietbird;340242
I don't know, but I could go for a box of dots candy right about now.
Vinnie, so how did that screw take so long to cause any problems? I mean did you recently do a visor swap? Or was it just grounded all this time and finally arced all by itself?
CoogarXR : 1985 Cougar XR-7
It had to have happened when I re-attached the visors after doing the sound deadener on the roof. It all sucks,but,on the good side,I got the replacement,minty fresh dash installed, power passenger seat, and a lot of the Zillamat. The car is a LOT more quiet inside now.A HUGE difference for the better.Comfy inside,grumbly on the outside.
What I meant was, when I first viewed this thread, all that was there was the first paragraph, no pictures or the rest of the post.
jeez dude what a mess.  Electrical problems are the fn worst man. Especially  like that...
Lol... now that I look back at that pic...... That thing is really cooked. Your so lucky the car didn't catch on fire from that. On the upside, I now know all the wiring from the fuse box, all the way to the trunk.
I started typing,then posted,went back to photobucket for a pic,came back and typed some more,posted,went back for another pic,came back and finished.I was distracted.
Quote from: vinnietbird;340281
I started typing,then posted,went back to photobucket for a pic,cam back and typed some more,posted,went back for another pic,came back and finished.I was distracted.
I think they call that ADD or OCD .
 That really could have been much worse I'm glad it's all sorted out now
Quote from: daminc;340280
Hey,I'm glad you learned from my ordeal.LOL. I''ve kept that fuse box.I need to put it in a shadow box and hang it up somewhere.I know a lot more than I did before I got started on the repairs. Yep,learning the hard way. Nothing quite like it........thank goodness.
Quote from: hypostang;340283
You're right,it could've been a big fire. For everything I swapped and the work i did,I really did get lucky considering what could've been.....fire,Burned interior,cooked Sport,Vinnie crying......the list goes on.
That must've been a nightmare, at least it's fixed now. Screws through wires cause a lot of hard to find problems for people.
Matt
Honestly,it was a nightmare.I slept like  every night wondering and buttstuffyzing.I felt more than relieved when I found the screw through the visor harness wire. Like I said,though....I did a lot of work I wasn't planning on til next spring (finishing the Zillamat,passenger power seat,replacement dash). It's all done now,so,I can sit back and find new projects I want to do.
Quote from: vinnietbird;340291
Want to come to Tennessee and help me take all the extra emblems off my car ??:mullet:  lol
 Vinnie, that looks like it was a hell of an ordeal.  Electrical problems are hell on earth sometimes.  Glad you got her going again.
