Topic: Parts needed for Samanthas 88 cougar (Read 1550 times) previous topic - next topic
Parts needed to rebuild my car:
Front bumper assembly
Front bumper
Front bumper (cover)
Grille assembly.
Front end panel
Headlamp assembly.
Hood panel latch
Hood safety catch
Hood lock
Hood hinge panel for the left and right.
Radiator panel
Front fender for the left.
Front fender repair for right.
Fender assembly
Please help my car is broken :hick:
I also need my car to be welded and the frame is bent.
Is this considered a front end assembly?
This is what the tow place sent to me.
i have some ls parts but they arnt all that great from an 88 v6. i may have a grill and if by some odd ball chance the bumper itself, but i dont think any of it is in suburb condition i can check if you wish
P.S. looks like that passenger headlight and signal assy is flawless so one less set of parts to find there...
All those parts you've listed is referred to as the front clip.If the Ebay listing above is actually the Cougar lights (it states Cougar/Thunderbird),then that is a great buy for a new pair.If I can get to a salvage yard soon (my favorite one)I'll see what I can find.Until then,I'm sure members will show up.
I have the safety catch in great shape (two of them actually).
I contacted the guy about the light (first ebay listing above),it's a single left side headlight for a Thunderbird.To read the ad is kind of confusing.It's also kind of high for one light.
I will have to look but I have a pair of fenders a turbo hood and I am sure a lot of misc. parts. I do not have a bumper cover header or lights. I may have a grill.
I do have a 1988 Cougar XR-7 that I am looking to sell as well.
Let me know if I can help
Ken
Do you have better photos of the damage in the engine compartment and the core support area?
Thanks
Ken
I have no more pictures because my hood is jammed shut so in order to get that open i will eventually take my fenders off too see.
I have the following parts;
Fender
Frt bumper cover
Grill
Hood
Possible the headlight,marker and turn signal
Quote from: 5.8fastcat;249172
Fender
Frt bumper cover
Grill
Hood
All in good condition?  How low are you willing to sell these items for ???
i only have a white hood. If you don't have one yet if you pick it up you can have it. its located i LeRoy NY.
Got that fox rash again!
-Resident smartass! :ies:
I just got you PM, and sent my email address. I will get some photos of my 88 out to you.
Thanks
Ken
i sent you a pm about a bumber cover and bumper.
in my opinion and in light of your needing to save money,,,
Quote from: Samantha;248783
(weld that piece back on)
Front bumper
(cant see where that plastic bumper is actually broke)
(dont need, plastic weld kit can fix all that)
Grille assembly.
(need)
Front end panel
(called header panel, yes its needed)
Headlamp assembly.
(need)
Hood panel latch
(need)
Hood safety catch
(need)
Hood lock
(i guess you need it, not sure)
(not sure what this is)
Radiator panel
(pull and straighten, too costly to replace)
(dont need)
(dont need)
Fender assembly
(dont need)
Like on your bad news thread, all i can see you really need at this point is a header panel (contains the grille / headlamps). You need this part pretty soon because it will contain all the bolts that will tell you when your done pulling the frame.
You know full well your going to have it painted up front anyway, your fenders are not jacked up at all and there are no creases in critial 90deg bed areas. All of that minor damage can be tuned back in with common sense  basic tools and a little love.
Again, the header panel is the key part at this point,
here is what i think you need for the whole project
big stuff>
header panel
weld bumper shock absorber
bumper (not sure, cant see the real damage to it, the bolt holes are all that matters)
little stuff
grille or modified to a 20th looking grille (you can have fun doing this part)
driver lights
driver plastic molding (iirc)
hood lock
hood latch
test radiator
test AC radiator thing (see if its holding presure by pushing in valve, if so, let it leak off and remove/save / re-install / recharge later)
plastic weld the bumper cover
