Topic: Shaving weight (Read 2919 times) previous topic - next topic
Shaving weight
i have been thinking about trying to lighten my car up, but i dont know of any good places to start. im looking right now to be able to remove some weight without spending money, so any suggestions will be appreciated
Shaving weight
gut the interior and remove the sound deadener. is it for the steet?
Shaving weight
yes it is a daily driver. i was thinking removing the air conditioner and the stereo stuff because the only time its on is when there is someone else in the car with me, which isnt very often
Shaving weight
Yeah the sound deadener is good for about 50 lbs(trunk also)other then free stuff passenger seat weighs a lot
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Shaving weight
Sound Deadner, Feltbackings behind rear side panels,behind rear seat
A/C and heater box,A/C condenser,Smog Pump
Shaving weight
remove the carpeting itself if ya want.
1987 TC
Shaving weight
spare tire all the sound insulation then i laid the carpet back down and put all the panels back w/no insulation behind them.
Anything else unnecessary or what you can deal w/out ex.air pump and A/C
Shaving weight
there was definatly a thread on this with the weight loss in pounds of each part. i cant find it though
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
Shaving weight
sleeper t-bird's thread?
1979 Ford Fairmont
[/B]
Shaving weight
there is insulation on top of the front splash guards, only a lb or 2 but still something. Convert to manual seats, pull rear seat, sound deadener above the headliner quad shocks, gut the trunk, switch to base door panels if you dont have them already. tubular k member if you what to spend the $
oh and pull the motor that will shave off a few hundred lbs real  easy:mullet:
Shaving weight
Manual seat tracks saves a lot of weight.If it's still for the street,and you'll be driving it a lot,keep the stereo.It's not that much weight.Sometimes a few comfort items can go a long way,and removing them is more miserable in the long run,and not worth the effort when it's driven a lot.
Shaving weight
Quote from: 32VFoxBird;228275
:mullet:
Shaving weight
I removed the sound deadening tar and threw it on the scale. It was roughly 42 or 43 pounds.
