Topic: 87/88 turbo stuff needed (Read 723 times) previous topic - next topic
Ok,,, my brother-in-law is putting an 88turbo into a pinto, he is in need of the computer, wiring harness and the vam meter. If anyone has and wants to sell please let me know.
Thanks, Joe
I have a computer ready to go.It's from an '87 TC,$30.00 shipped.
i have a big vam
someone was supose to buy it and havnt heard anything from him so its still for sale
make an offer
Vinnietbird- I will let you know on the computer, he has one intown place to check
Daboss- what size meter? OEM?, aftermarket?
Thanks guys
Quote from: flipnbird;221615
Thanks guys
hey there it would help to have the processor ID code so he could pick witch one is better for his app. Then as for the VAM there are only 2 sizes when is comes to ford 2.3T a small and a large. The larger the better but you would most likely want the ECU that was made fro the Big VAM. Same goes the other way around. Also the ECU determines what size injectors you are running so. The VAM, ECU and injectors need to match. Then Most any ford 2.3t harness should work but depending on the ECU it might need to be repinned or wires added. So I say tell your friend to head over to http://www.turboford.net/cgi-bin/ultimatebb.cgi?&r=actu
That is the place to be. He can get all the info he needs there. Most are doing it the lowest buck possible some do it high dollar.
I'll post it after work.
