Topic: Mass Air H.O. and T-56 conversion done (Read 5757 times) previous topic - next topic
1997 Mountaineer 5.0 with:
Ported GT40P's with 1.55 ex. valves
Ported lower intake
E-303 cam
Ford Racing 1.7 RRs
Ford Racing 70mm TB
PMAS 75mm MAF
24lb Injectors
MAC Shorties
Accel Ignition
D&D Performance T-56 Kit with:
PRO 5.0 shifter
Zoom 2.5 clutch
Steeda quadrant/firewall adj.
GT40p 5.0 w/ vortech @ 9.5psi, 400rwhp
I am still working on the Autometer Gauges so I will have more pictures soon. The car runs great and has lots of power. Still have the 2.73 7.5 out back, the '88 TC brakes and rear axle (3.55 for now) are next next.
Wow, thats beautiful.  Your car looks awesome, inside and out.
Sweet.One more car finished with a manual tranny.I have GOT to get mine finished !!!!
Nice,so the e303 and the 1.7s work good for ya,no clearance problems???
T56 is that a 6speed???
Did you have to get a custom driveshaft??
You've got basically the same engine I do (with a different cam). Torquey SOB isn't it? ;) I have mine bolted up at an AOD but I have 3.73 gears. Makes for a fun drive.
 now I want to drive mine but I can't. The roads are covered in salt and there is 12 inches of snow on the ground.  winter.......
very cool, you are the first on the board to swap in a 6speed (successfully, as far as I know), need all the info on what was required for it, LOL.  why didn't you paint the engine bay while it was out?
I hate you. That is basicailly the same thing I wanted to do with mine...
Thanks for all the positive comments.
Quote from: dominator;201608
Yeah, it worked. The guy that ported my heads thought I should be OK with ptv clearance and I've heard of other guys getting away with it so I sent the 1.6 RRs back and got 1.7s. Put it in straight up. Never did properly check ptv, just like to gamble I guess.:hick:  Yes it has 6 forward gears. Yes, the driveshaft was a custom piece and part of the kit from D&D.
Quote from: thunderjet302;201643
No, it doesn't seem very torquey at all. It's quite the opposite really. Don't get me wrong, it's got torque. It just has WAY more top end. I don't have the flow numbers infront of me but I think it was 215-220cfm @ .550" lift with the intake bolted on the head. It will be much more fun to drive with better rear gears.
The E-cam has less low end grunt than your 266 cam Tjet....
VERY  good lookin engine!!!  Those flow #'s are awesome for GT-40's!
Quote from: 1WLD BRD;201659
I just didn't feel like painting it, maybe next time around.
I had to buy the following:
T-56 (came with shifter and bellhousing but got the Pro 5.0 shifter)
Crossmember
Driveshaft
Clutch
Clutch Fork and cover
Clutch cable (w/ firewall Adj. and alum. quadrant)
Clutch pedals (from a mustang)
A new gear for the VSS (got a new sensor too)
Shift / boot
ATF
D&D sells all the required parts with their "bolt in" kit to make it as simple as possible to install it in a Mustang. I just had to buy all the parts as if I was doing a T-5 swap. I did have to do some cutting around the crossmember to make it fit.
http://ddperformance.com/T56%20Kit%201979-1993.htm
Not the best looking cuts but it works. All the trial and error left me with some jagged edges.
Very impressive.Kinda makes you proud,doesn't it?
That's why I'm showing everyone on here. I love my car.
