Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1459737 times) previous topic - next topic
Reply #2445
Quote from: daminc;330988
Found some old stock moulding....The box was very dusty and had a 1992 date on it.
See what happens when the garage gets cleaned?
1987 TC
Reply #2446
Started to figure out where everything bolts back on today. This is really tough seeing that when I took everything off, it was covered in a thick layer of gunk. Nothing really looks the same as when it came off. lol
I'm liking this color combo so far
Reply #2447
NICE !!!! You're getting there. Um,I'm going to go ahead and assume you KNOW,that the water pump isn't on yet.....riiiiiiight? LOL.
I spent a lot of my day looking at brackets as well.
Reply #2448
water pump?.... Where does that go?
lol
Nothing is really bolted on. just looking for where they go. I'll have my new pump on Tues.
Reply #2449
I ordered my Good Year belt from eBay and got for almost $20.00 cheaper than the parts store. If the parts stores around here could get Good Year belts......which they can't. The Gator Back belts don't tend to get cracks in them like others do due to their "tread design". Your dash piece is going out tomorrow.
Reply #2450
Send me a link to the belts if they have more
Reply #2451
Here you go. He had quick shipping,and the belt came in a little box.Perfect part.
http://cgi.ebay.com/ebaymotors/THOMAS-BUILT-MACK-GOODYEAR-BELT-4060930-GATES-K060930-_W0QQcmdZViewItemQQitemZ200276167615QQptZOtherQ5fVehicleQ5fParts
I think he has two left.
Reply #2452
Thanks for the link........
Did some remodeling yesterday.
tried to get the mig into all the spots and make a nice weld, but it was almost impossible with the other tubes in the way. did the best I could. I'll have to do a little more cleaning up before I'm finished. But now there's a ton of room for the plugs.
put a silver coat on the covers. they started turning dark already. also have more painting plans for them.
Reply #2453
The valve covers look great. Is ther room for the new header tube to fit next to the inner fender?
Reply #2454
Quote from: vinnietbird;331174
I'm hopin
Reply #2455
I never really looked at the distance between my headers and the inner fenders.They fit,so,I was happy. If it's too tight of a fit,just cut a hole in the inner fender for clearance.LOL.
By the way,I was looking at the wood grain dash panel.It looks to be in nice shape (a little dirty),but there are two tiny holes drilled into the base of it.I think,from what I can tell,the shifter panel will cover it.Just to let you know.
Reply #2456
If they show, I'll tell everybody they're drainage holes.
Reply #2457
As for the pipe clearance... It might be in Gods hands at this point. If it doesn't fit. then I'll figure it out. I'm like that. It's never really a problem. Even when everybody says it is...
Reply #2458
I agree. I've gotten so deep that failure just isn't an option. There's always a way if you think about it enough.
Reply #2459
Here's a dry fit of the center console. Nothings screwed down yet.
got another cover for around the shifter. this one seems to be painted.
still have to remove the column shift, and a bunch of work before I can finish putting it together
Guess I need another plate for the bottom space of the dash.
I guess I need to blank out the gear selector on the old cluster. I feel like I'm working in reverse on this car. lol
