Topic: rebuilt my motor (Read 12832 times) previous topic - next topic
rebuilt my motor
Its only been 2½ months
Finally posting that I’m complete w/my rebuilding of motor. Here we go starting from the bottom.
ROTATING ASSEMBLY is stock E7 crank cut .020 fresh rings & bearings. Fulton street machine shop in Farmingdale did all my machine work. Mellling high volume oil pump new pick-up and pan.
CAMSHAFT TFS-1 not degreed just put in at “0”
HEADS GT40 irons milled .040 w/a .039 compressed felpro 1011-2 gasket approx 10:1 compression. Exhaust side is mildly ported thematic bump grinded down; intake side just touched the impurity’s inside and the bur on the end (not much I now)
INTAKE explorer GT40 touched a little w/the grinder same as the intake side of the heads
TB 70mm BBK, EGR eliminator bracket
Still running the 19lb injectors and stock mass air meter (right now this is my weak point) I did inquire 24lbers from a J/K 460 for free but have no maf to match right now.
BBK fuel pressure reg
BBK cold air
EXAUST-FRPP shorty headers to BBK X-pipe (no cats) to straight pipes going out back. Need s to loud right now.
Other HP helpers
Smog pump deleted
A/C deleted
Electric fan
ChuckW motor mounts
High energy ignition coil FRPP wires
TRANSMISSION- Lentech street terminator with O/D delete switch
With a 2600-2800 stall converter
REAR still stock 7.5 w/3.55 in it. Soon upgrade T/C 8.8 rear in garage waiting not decided what gears to run though 3.55, 3.73, or 4.11
Other late mod is 140 Speedo that I’m still trying to figure out.
Took all summer to rebuild, finally cranked it over/started it at the end of September still no time to drive it finally posting this by the time I’m done w/this car it will truly be a classic.
OK heres my dumb/I’m still a kid question what’s some of your opinions of how much power I’m making (FHP or gross)(FHP w/ac or NET) and (GWHP or rear wheel
 NET) and (GWHP or rear wheel)
Short and sweet video gotta get s, but it’s the car at idle showing off the thundercat electronics sequential taillights
some motor pics
 Before I put the motor in I put some fresh paint on, wish I didn’t rush it though but it came out better then I thought for a rush job.
heres the lentech trany next to the AOD check out the shafts
the old stall next to the newer stall converter
the O/D delete switch
rebuilt my motor
Looking good :D
rebuilt my motor
Sounds like a nice combination, but please put some lers on it! Nice looking engine bay. I would go with a 3.73 or 4.11, depends on what type of driving you will be doing. I am no good at guessing hp.
Jim
rebuilt my motor
Nasty set up, sounds amazing!!  I like it with no s
rebuilt my motor
I'd say you're not too far behind me Bill,  Maybe 25-30 less, but you have 3.55's as opposed to my 3.27's  What's the weight like?
Oh yeah,  I gotta get me one of Carm's light kits!
rebuilt my motor
Next video you gotta get on it a bit!
Sounds wicked!  Great job.
:pics-stfu:
 Project Thread with pics
rebuilt my motor
sweet sounding ride!
rebuilt my motor
Thanks guys
Yes now that I figured out youtube ill try and get more video of my car what you saw wasn’t intended for the engine running it was actually for the taillights but I figured while I’m filming I might as well have the engine running. I installed them thanksgiving morning that’s when I get time to do things.
My guess on horsepower is staring at a 225 net HP E7 motor.
Better breathing heads cam intake at least 40hp
Compression a full point the book says 30hp
Other helpers exhaust, pulleys a/c & s/p delete elect/fan etc. another 25-30 hp
About a 100hp gain.
Id say it’s safe to say 300 but hope its 325.
But I don’t know.
rebuilt my motor
Your around 300,looks good,I like the valve covers.
rebuilt my motor
For gears I'd go with 3.73s. My combo is almost the same as yours (I have a different cam) and it really likes the 3.73 gears ;)
rebuilt my motor
Now all you need to do is junk those shorty headers and go with a set of long-tubes. :hick:
Looking good...get some slicks and gears in that T/C rear and use that transbrake...I want to see what this thing will run!
rebuilt my motor
ditto on the valve covers, May I ask where they came from?
1987 TC
rebuilt my motor
Quote from: HAVI;192286
Stock stang ones cleaned and painted w/aluminum engine paint.
There is no way I’m paying 140 for a set and it is going to give me no performance gain
rebuilt my motor
Quote from: Sick88Tbird;192281
Have a set of summit headers think there the same as flowtech couldn’t get them in at the time (2years ago)
Can’t wait for the rear to go in
The trany didn’t come w/a trans brake that would have been a bonus
rebuilt my motor
Had me fooled on the V covers,sure look alluminum.
