Topic: OFFICIAL Fox T-Bird/Cougar REGISTRY thread, 103 Total now! (Read 28436 times) previous topic - next topic
Quote from: 20th anny 5.o;133715
Year:1999
Make:Mercury
Model:Cougar
Trim:?
Original Engine:2.5 Stock
Original Trans:AOD
Paint Color:Black
Interior Color/Material: Grey/Black Normal type material
VIN: Too late to check
Options:The most bottom of the barrel v6 model you can find
Door Tag Codes:Too Late to check
Radiator Tag Codes:Too Late to check
I doubt your fwd cougarprobe has a rwd trans in it :p
Year: 1988
Make: Mercury
Model: Cougar
Trim: XR-7
Original Engine: 5.0
Original Trans: AOD
Paint Color: orig Oxford white
Interior Color/Material: Dark blue leather
VIN: I'll fill in later
Options: ATC, Power Moonroof, Leather, Dual power seats, Power Windows, rear defroster, interval wipers, tilt wheel, speed control, illuminated entry, full electronic cluster, premium sound, graphic equalizer, power antenna, luxury lamp group (on/off delay, auto dimmer, cornering lamps), luxury light group (engine compartment light, dual-beam dome/map light, instrument panel courtesy light, dual illuminated vanity mirrors, illuminated entry system) , power lock group (power door locks, power decklid release and power fuel filler door release), keyless entry
Door Tag Codes: I'll fill in later
Radiator Tag Codes: Only the bolt holding the edge of it is there.
Year: 1986
Make: Mercury
Model: Cougar
Trim: GS
Original Trans: AOD
Paint Color: orig Medium Canyon Red Metallic (2M)
Interior Color/Material: Grey/cloth
VIN: Add it later
Options: 5.0 V-8, 7.5 traction lock, AC, TRX wheels
Door Tag Codes: I'll add later
Radiator Tag Codes: I'll add later but the only code I recognize on there is the paint code.
Quote from: Aerobird Motorsports;133718
I thought 20th Anny's were all XR7's?? I need far more info on the options too.
From what I read, the 20th annys were not XR7's. I did a little research a while back because I thought the same thing. Maybe Eric or any of the other anny owners can give more info on this.
Our web page
02 Explorer XLT 4.0L
04 F150 FX4 Supercrew 5.4L
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
Quote from: 1badcougar;133737
http://www.coolcats.net/fox/20thanniversary.html
Based upon the LS model, it featured a special Cabernet Red exterior with Midnight Smoke moldings.
You know what I find interesting though. I was just looking at the Toolkit booklet for the 20th. On page two the heading says "1987 Cougar XR-7 20th Anniversary Edition Convenience Kit".
That is the only idiosyncracy...and I'm betting it was because a different company printed that booklet. Mix-ups happen all the time in the printing industry, especially in the 1980s. The 20th was NOT based on the XR7. It was an LS with the proper option package. This is taken straight from the Ford ordering literature. See here: http://www.coolcats.net/fox/20thanniversaryoptions.html
The follwing order codes were used when ordering the 20th Anniversary Cougar:
M60 Cougar LS
170A Preferred equipment package
99F 5.0L EFI V8 engine
2H Medium Cabernet Red exterior paint
TY Sand Beige Ultrasuede/leather interior
Year:1987
Make:Ford
Model:Thunderbird
Trim:Turbo Coupe
Original Engine:2.3T
Original Trans:T5
Paint Color:Medium Red
Interior Color/Material:Raven Cloth
VIN: 1FABP64W6HH******
Options:Power Moon Roof,Keyless Entry,Climate Control,Premium Sound,graphic equalizer,Power Driver seat,Luxury light group (engine compartment light, dual-beam dome/map light, instrument panel courtesy light, dual illuminated vanity mirrors, illuminated entry system) Power Windows, rear defroster, interval wipers, tilt wheel, speed control, illuminated entry,power lock group (power door locks, power decklid release and power fuel filler door release),Rear Defrost,carpet floor mats
Door Tag Codes:1/87, FOO21, ROO19,DSO 28,BOD 63D,INT TRIM BH,R H,S 8 ,AX K ,TR 2UUKK
Radiator Tag Codes:Tag Missing
So the 20th Anny ISN'T an XR7? See, I'm learning stuff already! :P
The White one in my sig
Year: 1988
Make: Ford
Model: Thunderbird
Trim: Base
Original Engine: 3.8
Original Trans: AOD
Paint Color: White
Interior Color/Material: Red/Cloth
VIN: 1FABP6042JHXXXXXX
Options: Auto-Dim, Cornering Lamps, Power driver's seat, PL, PW, trunk release
Door Tag Codes: 9L(ext paint)...63D(body)...HD(int trim)...H("R")...Y(ax)...TJCDD (the second letter is either a j or i, can't tell which)
Radiator Tag Codes: tag missing
the 1988 TC I parted last summer:
Year: 1988
Make: Ford
Model: Thunderbird
Trim: TurboCoupe
Original Engine: 2.3
Original Trans: T5
Paint Color: Maroon
Interior Color/Material: Raven and Gray/Cloth
VIN: 1FABP64T9JHXXXXXX
Options: Power Driver's seat, PL, PW, trunk release
Door Tag Codes: ext paint=26....int=BH...."R"=H.....Axle=K........trim=2SSKK, and above that: F0084 and R0032
Radiator Tag Codes: missing
the TC had a build date of 04/88
my first Tbird, also maroon
Year: 1988
Make: Ford
Model: Thunderbird
Trim: Base
Original Trans: AOD
Paint Color: Maroon
VIN: 1FABP6041JHXXXXXX
Options: Auto-Dim, Cornering Lamps, power, driver's seat, PL, PW, trunk release
Door Tag Codes: ext paint=26....int=HD......R=H.....Axle=Y.......trim=TCCDD  F0076 and R0083
Radiator Tag Codes: long since missing!
build date of 10-87
Added everybody that posted so far except FILA cause he's missing everything except that it's a white FILA.
Michael, not meaning to be an a$$
My medium canyon red wasn't clearcoated.
Just trying to help you get more accurate info ;)
Year:1987
Make:Ford
Model:Thunderbird
Trim:LX
Original Engine:5.0
Original Trans:AOD
Paint Color:sandalwood/brown
Interior Color/Material:grey/velvet-ish
VIN: 1FABP62F4HH108438
Options: pwr windows, door locks,single power seat,cruise,tilt,10" brakes, base dash,ill. entry, intermediate wipers
Body: 63D
Interior trim: KE
Tape: 4H
AX: 8
Blackjack, I need FAR more info then that. Come on man, put a *little* work into it.
5.0willgo, all myliterature shows that all years med canyon red is clearcoat metallic and that the only "regular" one is Bright Canyon Red. Which is yours?
Quote from: EricCoolCats;133742
As far as i know the 20th anniversary's had XR-7 Suspension.
Quote from: Aerobird Motorsports;133775
I have paint code 2M, Medium Canyon Red Metallic. Eric has that listed as not being clearcoat on his site(unless he mistakenly mismarked it)
Maybe I'm wrong.
Unfortunately it isn't as simple as looking over the car for traces of clear since it was resprayed black :(
*EDIT - I found some color chip pages online and sure enough, they show it is clear coated. It's interesting that some '86 Mustangs the same color aren't clearcoated.
Learn something new every day.
Michael, I added the door tag info of my TC and the other Tbird.
I'm curious what the top right numbers designate..F0084-R0032 for the TC, and F0076-R0083 for the V6 car.
