Topic: Changine heads (Read 1952 times) previous topic - next topic
Changine heads
Since I have a flat tappet can, can I use E7's, which are roller rockers. If I do, can I just use the Ho cam insted of the flat tappet? This may make no sence, so please try to help me out here.
Changine heads
You can use E7's with a flat tappet cam.  You can't use a roller cam in your block.
Changine heads
At least not a STOCK roller cam.....You can use a retrofit, but they are usually a bit pricey.
Changine heads
I think the only 5.0's that came with roller rockers were the '93 Cobras. But you can get pedestal mount RR's for those E7 heads, they bolt right on. That's what I have for my p heads.
GT40p 5.0 w/ vortech @ 9.5psi, 400rwhp
Changine heads
lol, no m8 we wish of our cars came with roller ROCKERS. we're talking about roller lifters. and mike's doesnt have roller lifters, therye flat-bottomed. i think 86 was the first year for rollers..??? someone correct me if im wrong.
Changine heads
Ok, so what exactly do I have and will E7's work? If not or if it will, reguardless, what do/should I do
Changine heads
Quote from: ZondaC12;125147
93 Cobras came with 1.7 roller rockers on GT-40 heads.
Changine heads
Bah! You and your alphanumeric words. I'm sleepy... bed time.
Changine heads
unless you have a pre '80 block its drilled and tapped for a roller cam or it at least has the bosses for them, a retrofit kit is only the spider and seperators. what did your engine come out of?
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Changine heads
From what I was told, I only put it in, is an 83 LTD and the CFI came from an "Ho CFI stang". I didn't pull the motor, so I can't help. THe only thing I can do is give the date cond on the intake, which I will have to go look.
Changine heads
look right above where the starter mounts and get the #'s from there and post em also if it has a 1 peice rear seal it will also be steup for a roller cam
Changine heads
I will tomrow ( it's snowing) and I *think* it was a 1 peice.
Changine heads
you said that motor was an LTD transplant.  did you find out something new ?  HO stang CFI????
yes, e7 casting numbers will fit on you engine,,no problem, no mods,,plug and play.  Complement it with that 4bbl intake you mentioned and top it off with a carb if you wanna.
you should really do a compression test before and after, just to see the difference.  You might find that since you have the upper half off, its soooooo easy to c00ch the block (making it sound easy here) and toss in a re-ring kit while your at it.
Changine heads
Steve ( reputiable freind) said he took the CFI of his 84 Stang HO CFI and put it on the Fila. Probaly BS but only part #'s can tell. and if I have the heads off, I might as well put the 4 barrel on it too
