Topic: Chuck W (Read 1094 times) previous topic - next topic
Chuck W
Chuck
do you have a pattern on the 5.0 engine mounts? In a drawing that can be posted or emailed?  It would be nice to have it when i make my next set.  I have my own now but they are flat from the block to the mount.  I know tom said there is about a 7/8 '' transition in height but like i said,, it would be nice to have the pattern.
Chuck W
You'd think I would have seen this a couple days ago.
PM me.
Chuck W
here is what i plan on doing with some decent 2x4 7/16 angle iron welded back to back.
all i was really wanting was the measurements on hole orientation or just the measurements from the rear of the block to the motor mount hole.  I suppose i could go off what i have and tinker.
I have made myself a set of flat mounts identical to this with no offset.
the distance for the motor mount holes are not the same on each side.  I came up with 3/4'' difference making the longer line on the driver side.  I understand what you mean though.,,, thanks for the exact measurement.
Chuck W
You got the dimensions, but the holes are actually the same fore and aft on the mounts,  the width is what is different.
