Chuck W December 11, 2006, 11:21:09 PM Chuckdo you have a pattern on the 5.0 engine mounts? In a drawing that can be posted or emailed? It would be nice to have it when i make my next set. I have my own now but they are flat from the block to the mount. I know tom said there is about a 7/8 '' transition in height but like i said,, it would be nice to have the pattern. Quote Selected
Chuck W Reply #1 – December 13, 2006, 10:26:22 AM You'd think I would have seen this a couple days ago.PM me. Quote Selected
Chuck W Reply #2 – December 17, 2006, 03:20:08 PM here is what i plan on doing with some decent 2x4 7/16 angle iron welded back to back. all i was really wanting was the measurements on hole orientation or just the measurements from the rear of the block to the motor mount hole. I suppose i could go off what i have and tinker. I have made myself a set of flat mounts identical to this with no offset.the distance for the motor mount holes are not the same on each side. I came up with 3/4'' difference making the longer line on the driver side. I understand what you mean though.,,, thanks for the exact measurement. Quote Selected
Chuck W Reply #3 – December 17, 2006, 03:40:56 PM You got the dimensions, but the holes are actually the same fore and aft on the mounts, the width is what is different. Quote Selected
