Topic: 87 bird vibration (Read 1643 times) previous topic - next topic
87 bird vibration
I recently acquired an 87 t-bird with the 3.8 that I am really starting to like.  One problem I just can't seem to figure is it has a vibration that comes and goes.  It almost has the feel of warped rotors but it sometimes comes in when I am just cruising on the freeway.  Seems to be centered under the center of the vehicle.  Almost always happens when I take my foot off the accelerator.  I had the trannie flushed and have tuned the engine which runs very smooth.  I wonder if it might be u-joint?  Any help?
87 bird vibration
if it only does it during cerain speeds  (like 40-60 mph) i'd balance your wheels, but if the tires arre newit may also be a slaightly egg-shaped tire, like a manufacturer defects. im not excactly sure what it'd be if it only does it when u let off the gas tho.
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
87 bird vibration
I'd have to check those U-joints right away (before one breaks at speed). You might wanna check the pinion bearing while you have the U-joint out (just see if the pinion has any up/down slop)
87 bird vibration
my vote is for the pinion bearing.  u joints are also part of it id bet
88 TC, Lots of Mods.
87 bird vibration
I'm going to have the u-joints and pinion bearing replaced over the weekend.
87 bird vibration
U-joints most likely....
