Topic: What's the hardest car part you've installed solo? (Read 3484 times) previous topic - next topic
I'm sure I'll see alot of engines and tranny installs but I'm still curious none the less. My hardest just happened last night. I installed a rear end all by myself. It wasn't that bad at first until I had to align and jack the  thing up at the same time! And the higher it got the more unstable it became. It nearly rolled right over me. =/ But I got it in and that's all I cared about.
Other than that the other worst was removing and installing a nearly 3/4 full gas tank in an apartment parking lot. That... sucked... ass.
All my work has been solo...from pulling/installing engines, trannys, rearends.....I never have a helper....so I guess I'm just used to it.
Engine and transmission, or just the transmission...didn't care for doing either one of those myself but I didn't have much choice.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Ditto on the rear end. I caught hell trying to get everything lined up and keeping the diff balanced on the jack at the same time.
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
Wiring CFI ALONE!!! It sucks.
I think it's tied between the rear end and the gas tank.  Bleh.
It may be a 3 way tie with dealing with the front suspension as well.
Willpower is no match for Horsepower.
fuel injection on my 77 f250 and engines and trannys
Considering I haven't done much to my car by myself since I've always had help on everything, the hardest thing was the intake manifold swap (which I did all by myself). Now that sounds stupid I'm sure BUT it wound up being a royal pain that caused me to spend a lot more money than I antited.
-Original bolts broke, had to buy new and drill out the broken ones.
-Couldn't easily remove hoses so I had to cut, wohoo fresh hoses.
-Fuel injectors crumbled, had to get another set
-I get the whole thing back together to find I broke the heater core while either removing or installing the hoses.
Hmm, I was thinking about swapping a rear. With all these "rear being the hardest" posts, I'm having second thoughts.:giggle:
lol, I forgot about one. Prolly because I did not accomplish it. I tried and failed to install a C4 alone. The car wasn't high enough and I couldn't roll it under the car on the jack. After sliding the C4 under the car (after taking off the bellhousing) I couldn't get it back on the jack. Defeated.
I generally work alone now because I don't really know that many people that work on their car up here.
Quote from: Ether947
Headlights.
Both motor mounts on my '88 XR7.
Oil pan, 5.0... 'nuff said.
Ill let you know in a few months...because everything will be getting swapped out.
It's Gumby's fault.
5 Hours with my head under the drivers side dash wiring a keyless entry and remote start system on my 88 Bird.
NEVER AGAIN!!!!
