Topic: BF Goodrich Radial T/A (Read 2636 times) previous topic - next topic
Who needs spoogehos anyway?
These are the tires I am getting in a few days. They will go with the turbines that are going on my Cat. Winning combination? I think YES!
Has anyone had any experience with them?
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
I have! I had those on my car. They look no less than awesome with the turbines. However be careful in the rain and take special care when they wear down.
They are fine on dry ground but past that, they are a little funny. Starting from a stop, they may easily spin if the road is wet so just keep that in mind. Mine wore down in a little over a year, partially due to a really rough winter. I wouldn't recommend driving with those in snow.
I'm running with Traction T/A's now and the difference is like night and day. But I did have to give up the cool look of the white lettering.
Quote from: 5.0willgo
They are fine on dry ground but past that, they are a little funny. Mine wore down in a little over a year, partially due to a rough winter. I wouldn't recommend driving with those in snow.
Thanks for the advice! Right now I am stationed in Georgia, so snow is the least of my worries! :giggle:
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Hahaha, that combo would make your cat look very nice! i like that. What tire size you are going to use ?
1985 Mercury Cougar V6
1989 F-200 V8
1996 Explorer V6
2001 F-150
I have always liked the T/A.  I have also always had good luck with them in all weather.  I say good choice!
I have thost on my Crown Vic'. Good all weather and I ran an 15.4 with them. I rthink you should use them.
yep i had them. still do. they smoke up good also. they are a good cheap tire  and hold the road ok. but like said b4 in the rain a little funny. just meke sure that they are filled to the prople air psi and you will be fine. and yes when they get worn out get ready for the slip and slide action  oh yeah westleys bleach white is a must to keep the letters white.  good luck. youll be happy.
trick flow street heat intake , 24lbs injetors, ported GT-40's (Chip) long tube headers. and a Performance Automatic C4, with a hurst shifter!
id go with the spoogeho's
t/a's and rain do not go together plus there pretty hard and spin easy.
IMO, They are a good everything tire but it's dependent on the driver style. There are better and worse one's out there but these just seem right to me.
Quote from: MexCougar
Hahaha, that combo would make your cat look very nice! i like the that. What tire size you are going to use ?
Thinking about
P215/70R15
or
P225/70R15
what do you think I should go with?
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
I had 225/60 15 on front 235/60 15 on back.
The rears were a bit wider and slightly taller than the front.
Keep in mind the standard size tire for the turbine is 225/60 15.
When you go up to a 70, the tire will be taller but not wider.
If you want wider, adjust the first number which is the width in mm.
Also increasing the diameter can throw off your speedo.
Here's a link to a calculator...http://www.buicks.net/shop/reference/tires.html
I ran 215/70/15's in the front of my 86 and 235/70/`15's on the rear for the big and little look without a chance of  rub
So is 225/60 15 on front 235/60 15 on back the setup you recommend?
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Quote from: Carl
Not really; I don't recommend anything. I was just giving you a setup I had for reference. It worked out fine and wasn't overkill IMO.
Its your preferance and all depends on what you are looking for.
Now I have 225/60 15 all the way around. Its nice to be able to rotate my tires. :hick:
So what are you looking for?
Narrow up front, wide in back staying approximately with the stock height?
Narrow and short up front, wide and tall in back?
Widest you can fit on the rim?
Bigger on the back without sacrificing too much handling?
Don't know how much help I can be on good combos. I've only tried that one.
That is what I will go with.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
