will it be OK
Reply #3 –
The only thing you might have to watch out for is if you car is a column shift...in which case you will most likely have to do one of two things...modify the shift linkage slightly(someone posted a diagram up here before) or install a floor shifter. If you already have floor shift, you need not worry. The reason for this is because the HO style headers exit further away from the block than the SO log manifolds. But, the effort will be well worth the gain. I will be having 3.73's installed tomorrow and I can't wait.
I would actually recommend that you not go more than 3.55's if you plan to keep the SO 5.0 because it falls flat on it's face much earlier than the HO. I believe they were rated at 165hp@3200rpm or 3500rpm, which is rediculously low. If you plan on doing an HO swap, or significantly adding power another way, then installing 3.73's in antition for that would be fine.
Also, if you plan on ditching the cats, you might as well gut the air pump and it's related hoses...knock some weight off and free up some horsepower buy turning one less pulley(you'd be lucky if it amounted to 1rwhp though).
