Topic: 88 302 H.O. conversion. (Read 903 times) previous topic - next topic
Hey yall,
I know that this has been asked aLOT before but I cant find them any more and I would like to know, what does it take to convert it as far as electricals and internals. Thanks
computer
heads
Upper intake and t/b
cam
Don't forget fuel injectors and swapping the firing order.
This should be all the information you need... under advanced info...
http://www.coolcats.net/tech/
Quote from: 5.0willgo
pulled from the link posted:
After all the parts are installed, you will need to reroute the spark plug wires. The firing order will now be 1-3-7-2-6-5-4-8, using the HO pattern. You will NOT need to change any fuel injector wiring in your stock harness for this conversion, no matter what anyone else tells you!
1979 Ford Fairmont
[/B]
