Topic: Gotta 1984 T-Bird and need help wit my engine (Read 2850 times) previous topic - next topic
Hey, I got a 84 T-Bird and need help wit what would be the best engine to put in it.
There are a lot of factors to consider.
First thoughts are to swap in a 302 or a 351.
first off welcome to the board. now to the nitty gritty. i love my 84 with the stock 5.0 but most will tell you its got no balls. id say get a 5.0 HO and call it good. the 4 head light cars are the best looking. good luck with it and have fun.
jeremy
put a 350 in it.  then search
Yeah My dad told me to go with a 351 Ci Cleveland if I could find one.  So do you guys think that would be the engine to go with?  But my brother said to put a 88 T-Bird Engine in it if i could. Its the 5.0.  and the engine in it is a 3.8 V6...
Oh your power is as sucky as the rest of us V6 people. Put a big block in it:D
SOLD!!!!
If you swap a 5.0 from an '88 Thunderbird, you're only getting the SO. Not a huge improvement for the work involved.
you could always get the block from an 86-88 cougar/tbird, 87 up mark7, couple  years of f-150's, newer explorer's, even the 87-91 crownvics.
Then save
$2000, and get the trick flow top end. That would put you at around 300hp, being very conservative.
However, the stock 88 tbird v-8 aint that bad. I can spin the tire on my 86 till about 20mph, cant do that on my 87 3.8, not even close.
Quote from: Haystack
When you're only spinning one skinny little tire, it's not going to take much to lose traction ;)
:grinno: :giggle:
Quote from: Chuck W
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
But I'm Running 205/60/R15's in the rear on american racing rims and the stock in front, on same type rims
And does the 88 Super Coupe T-Bird Engine put out more power?
Do you think it would be wise to run Nitrious or could I even do that...
What Engine is better for a 84 T-Bird?
351 Ci Cleveland or 5.0 V8 Super Coupe
supercoupes started in 89, and were V6s.:D
205's are not wide tires.... ;)
Pick an engine and put it in the car....
our poor message board
