Topic: Help with motor mounts. (Read 2336 times) previous topic - next topic
No spacer was used,
block plate from V6 worked O.K.,
I assume you meant the upper mount bracket?
Death awaits you all with nasty, big, pointy teeth.
1988 5.0 Bird, mostly stock, partly not, now gone to T-Bird heaven.
1990 Volvo 740GL. 114 tire-shredding horsies, baby!
Make sure you have the engine mounts on the right side.:D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Quote from: MasterBlaster
I believe he means the thin aluminum plate betweeen the engine and tranny... Would be the same on 5.0 and 3.8..
Quote from: cougarman
:D  The little things.....
Those little things have a easy weekend swap and turned it into a horror tale.  Every little thing that could go wrong, did.  But I see the light at the end of the tunnel finally.  Thanks again,  Fred
Thanks for the responses.
My last post, as I finally found the right combination of parts.  '83 V8 T'Bird mounts and the "double hump" crossmember, worked for me.  The trick Mustang convertible mounts looked good, but the engine wanted to sit lower than the "K" member would allow. Again, thanks for the guidance,  Fred;)
