Help with motor mounts. Reply #15 – March 28, 2006, 11:18:57 AM QuoteNo spacer was used,Quoteblock plate from V6 worked O.K.,I assume you meant the upper mount bracket? Quote Selected
Help with motor mounts. Reply #16 – March 28, 2006, 12:01:39 PM Make sure you have the engine mounts on the right side.:D Quote Selected
Help with motor mounts. Reply #17 – March 28, 2006, 12:28:55 PM Quote from: MasterBlasterI assume you meant the upper mount bracket?I believe he means the thin aluminum plate betweeen the engine and tranny... Would be the same on 5.0 and 3.8.. Quote Selected
Help with motor mounts. Reply #18 – March 28, 2006, 02:38:01 PM Quote from: cougarmanMake sure you have the engine mounts on the right side.:D :D The little things..... Quote Selected
Help with motor mounts. Reply #19 – March 28, 2006, 07:21:02 PM Those little things have a easy weekend swap and turned it into a horror tale. Every little thing that could go wrong, did. But I see the light at the end of the tunnel finally. Thanks again, Fred Quote Selected
Thanks for the responses. Reply #20 – March 29, 2006, 05:50:41 PM My last post, as I finally found the right combination of parts. '83 V8 T'Bird mounts and the "double hump" crossmember, worked for me. The trick Mustang convertible mounts looked good, but the engine wanted to sit lower than the "K" member would allow. Again, thanks for the guidance, Fred;) Quote Selected
