Topic: rev limiter (Read 905 times) previous topic - next topic
rev limiter
does anyone know where the rev limiter is located on a 1987 Ford Thunderbird with a 232 3.8L V6? Cuz it catches me at 85 miles per hour. but the only thing is that the sound will keep going higher but the speedometer will stop
rev limiter
That's cause you're actually going past 85, but that's where the digital speedo stops.  To fix that see here:  http://www.coolcats.net/tech/advanced/199speedo.html
rev limiter
Your car IS going faster than 85, the stock speedo doesn't read any higher after 85 though....
You can modify it to read higher, all the way to 199 mph, I did, and it's kickass! click the link to see how to do it..
EDIT:
, Paul beat me to it, hahaha
thanks
thanks man do you know what the top speed is? cuz i dont wanna blow my motor
rev limiter
Stop when the valves float :D
rev limiter
You don't have enough horsepower to blow your motor on a top end run (unless you try it in second gear or something). The V6 (and V8) versions of these cars will run out of steam long before they hit redline
The top speed of your car would probably be 110-120 MPH, maybe 130 if you're going down a good long downhill stretch with a tailwind...
rev limiter
Valve float occurs before the rev limit in a 3.8L. Dont ask how i know.
