miss fire while drive March 05, 2006, 08:39:17 PM what all could cause a tc to miss fire while driving, when it misses it shakes back and forth pretty bad, i was told it is the stator, i put sum plug wires on and the didnt help, so gimaa an idea what could be causein this to happen Quote Selected
miss fire while drive Reply #1 – March 07, 2006, 08:56:15 PM Does it do it cold? or hot? or both?What brand of plug wires did you use? What are you running for plugs?TCs are real finicky about plug wires. About the only ones that work consistently are the stock Motorcraft replacements, E8PZ-12259-A.Taylor Hi Energy wires work well also. I heard they can be had from Summit Racings. MagnaCores also work well. Just about everything else has caused problems sooner or later.Plugs are also kind of critical. I like the Autolight 764 coppers gapped around 0.032" Stay away from the platinums and such. You can also use Motocraft AGSF-32CF-4If your tuneup is getting kind of old (over 12K) or you don't have the right plugs and wires, consider doing those things first and see how it affects your problem. Quote Selected
miss fire while drive Reply #2 – March 08, 2006, 12:53:21 AM regaurding plug wires i just put on some ford racing 9mm, plugs im not sure cause i just got the car, but i am puutin new plugs in the beast, and im doin a cap ,rotor, and stator so hopeful,ly it will fix the problem Quote Selected
