Topic: Calling out Chuck W (Read 2602 times) previous topic - next topic
Calling out Chuck W
Figured that would get your attention
I just realised I  have never seen you car.  Have you got it back together enough to show some pics.:D  Ive seen pics of the roll cage and all but I would like to see the rest if its possible.
Calling out Chuck W
Well, aside from when I picked it up, it's been hiding in the garage and it's hard to get any good pics really.  I'm hoping the next time it comes out of the garage will be under it's own power.
Here's a pic from when I picked it up from paint
and here's a pic after some reassembly.
When the weather behaves a bit I may get it out for a couple more pics, but aside from engine/MeqaSquirt/misc progress pics I don't have too much.
Calling out Chuck W
Sweet.........is that an air dam behind the door?  did you do that yourself.....That just set off the car.  Its a great looking car I know you must be proud.
Calling out Chuck W
I had the painter do it...He was mucking around with the car anyway and he's the pro.
Right now it's just "dead", but it will be used for something later, but it was best to do them now.
Calling out Chuck W
ooo.. i guess that the exaust will be coming out of em! that would be sweet...
man oh man does that car look just bad ass...
/me runs to a private place to contemplate chucks car...
Calling out Chuck W
Looks great so far man.  What are you doing for powerplant?  2.3T or something wacky?  I assume its a 5 speed as well?
Calling out Chuck W
Current powerplant is 2.3T/T-5
Next winter project is a 200 X-flow I6 turbo conversion/swap.
Calling out Chuck W
Ok, so this is the car getting the I6.  I've heard it mentioned but was not sure what the I6 was going into.  That will be pretty slick man.  Are you still gonna run a T-5 behind the 6?  So will this thing be able to eat up those puppiesanese I6 Turbos or what?
Calling out Chuck W
Chuck W that Tbird is sooooo cool:bowdown:
Calling out Chuck W
Quote from: 50tbrd88
Dunno...it may just blow up in my face :hick:
It's going to still be the OHV  (no OHC for me yet...out of the budget), but it's (the head) AL and a crossflow design (unlike the cast iron lump o' the US 200/250's got).  This OZ head/intake will be mounted on a US 200 block.
The T-5 will be behind it.  The late 200's got a different bell pattern that is 2/3 of the 5.0 pattern, so mating a 5.0 bell/flywheel to it will be pretty easy.
The car will be running Megasquirt already, but I may build a new ECU that's set up for EDIS instead of tearing apart the current one that's built for TFI.  If I need to build a new engine harness I will, but most of the sensors should be in the same spots.
It will also get a new Kmember and engine bay paint at that time too...
Right now it's just getting it back on the road....
Calling out Chuck W
Tubular.
I have one hanging on the wall in the garage, but I need to mod it to fit the I-6 mounts.
Calling out Chuck W
Well I stumbled across a "recent" pic from when I was working on the cage....
Calling out Chuck W
That paint is B-U-T-ful
