Topic: floor pan (Read 1316 times) previous topic - next topic
floor pan
so...i still need too fix the hole in my floor. likely ill end up using some sheet metal but id like too replace it with a pannel from another car thats solid. i only need the corner plus about 5" around and up the side so i have room too work with. dont realy need all the way around the plug i guess. if anybody can hook me up with a clean peice that would be awesome.....thanks in advance...john
~John~
floor pan
Let me go out tomorrow and look at my maroon '88...
I thin that panel might be in good shape.
When I stripped the car in my shop, i used a tractor with a haysticker to pick it up and move it, did spear a hole in the floor pan, but not near that area, so I'll check it out tomorrow, and get back with ya...
I'll also take a digi cam and snap a coupla pics...
Only problem will be actuall cutting the  thing, as I have no torch or cutter thingie (die grinder?)
, I got a piece to help someone else out with, and can't think of a way to get it! lol
floor pan
sweet...well, im going too use a plasma cutter too cut them up but thats one thing...maybe a sawsall?
~John~
floor pan
Man I just sent my 87 to the junk yard.It had great floor pans in it, just way to much rust around the front and rear windows.The drains were clogged up so the water just rotted away the metal.
floor pan
Quote from: FordTruckFreeek
Pick up a 4 1/2" angle grinder with a zip-cut blade, theyre cheap and you will find tons of uses for it. Just make sure the sparks arent directly hitting anything flamable for too long... burning pantlegs arent fun if its you, if its someone else then its a different story:D
floor pan
yeah, was thinking along the lines of angle grinder, or a sawzall with a metal blade, i have niether, but I know of a place where I can rent one really cheap for a coupla hours...
floor pan
:banana:
~John~
floor pan
:sawzall:
~John~
floor pan
I'm going out there tomorrow to check it out, was there today but had so much to do, I didn't have time to get at it...
Seeing that I've got to get one of the tractors out to drag some cars and line up, I'll just pick the whole car up, and take it to the shop where there's electricity, and get what ya need.:)
floor pan
I ended up going out there this morning, when I couldn't sleep.
I picked it up, and set in on it's side so I could get a good look at the bottom...
Thing is, it's kinda rusty on the bottom, coupla smaller spots, and one big spot about the size of a baseball.
It appears like it's ate into it a bit, so I'll see what you wanna do.
I really didn't think that it was like that on the bottom, sorry man.
floor pan
awe its alright man...dont worry about it. ill see what comes up and ill let you know if i need it ;) i appreciate it nonetheless....
~John~
floor pan
bump-a-roo.....:sawzall:
~John~
