Topic: Truck troubles...EFI guys I need ya help (Read 1113 times) previous topic - next topic
The ol 300 I6 is giving me trouble...it "misfires/hesitates" on part throttle, 35-50 mph is the worst...you can hear/feel it sputter...I've changed plugs,wires,cap,rotor,HEO2 sensor, IAC, switched MAP sensors *used t-bird one...it sucked* when I switched map sensors it got a lil worse...but when I pulled the vacuum line off it still ran unlike the one that was in it...when I pulled it off it surged up and down. didn't find any vacuum leaks for that...someone mentioned to take off the T/B and clean it. also said sometimes they try to swallow the gasket? OUCH...I have a code reader...said Spout circuit was open, and the O2 was reading rich...has a new aircleaner....I'VE been chasing this for a month...so i'm discouraged
Quote from: 86Tbuzzard
They do tend to suck in the gasket.  Its definately worth cleaning the TB and replaceing that gasket.
In light of everything youve mentioned replacing, I can't think of anything else off the top of my head, but I'm digging around.
Check the spout and make sure it is plugged in good. If so the ign pick up in the bottom of the dist is pobably going out. It will cause the timing to jump around.
pickup? on the shaft or inside under the cap?
Inside the dist you have to press off the gear and remove the shaft
Might be something for you to check, I had a truck with similar symtoms after moths or replaceing and trouble shooting I was just cleaning the engins notice the wires for the O2 sensor had burnt slightly on the exhaust and was shorting on the block replaced the wires and problem was solved.  Also hae you checked your fuel pressure.
Our 91 EFI 300 did the exact same thing.  Same symptoms and everything.  Fuel pump was dieing.  New pump and it is back to being a stump pulling 300.  Its amazing what low fuel pressure will do to a vehicle.
it has 2 tanks...does it with both
Yeah but do you have a frame rail mounted pump?  Your truck may have 3 pumps.
Problem solved...only cost me a buck... the engine sucked in the T/B gasket, and the timing was too far advanced...I reset the T/B screw on top that acts like a stop for the throttle...so when I mash the loud pedal...the ol 300 I6 is there....
