Topic: 94 5.0 motor, MM suspension parts, lots of other stuff... (Read 983 times) previous topic - next topic
1994 Mustang GT engine. 140k miles, burn victim, new gaskets and seals. No accessories. Came from good running car before fire, still had crosshatching in the cylinders when I had the heads off. Comes with EFI mainfold and fuel rail. $350+ shipping or pick it up for $300.
1994-1998 Mustang 3.8 t5 bellhousing with clutch fork. Bolts up to 5.0 w/o mods. Degreased and painted dark blue. One broken bolt engine-->bell bolt, about 1 inch is still sticking out, so I think it would come out with some heat and PB blaster. $30+shipping.
Ford NOS 2.3T std. bore piston rings. Never used. $50+shipping.
'88 Thunderbird Turbo Coupe 8.8 rear axle assembly. 140k miles, 3.73:1 trac lok, no noises, never saw more than 200hp. Brakes are junk. Pick it up or arrange your own shipping; I can probably get it in a crate if need be. $150
'87 Thunderbird Turbo Coupe 8.8 rear axle assembly. 160k miles, 3.55 trac lok, no noises, lived behind my mild 2.3t. TC rear disc brakes are good, new pads. Trac lok rebuilt 500 miles ago. Complete. $225.
Maximum Motorsports 83-88 Thunderbird/Cougar, Lincoln Mk VII Rear Lower Control Arms. With sway bar mounts and std. spring perches. Some scuffs from installation, 5,000 miles. $200+shipping.
Maximum Motorsports 83-88 Thunderbird/Cougar, Lincoln Mk VII Caster/Camber plates. 1,000 miles. $160+shipping.
Bilstein 2000 Cobra R front struts, 30,000 miles. Excellent shape. $200+shipping.
H&R Race "Red" Mustang Springs. Front & Rear. 30,000 miles. $200+shipping.
PRC struts/shocks/springs/sway bars from my '88 Turbo Coupe. 140k miles, though the struts were replaced once in that time. PRC worked well when I took the car off the road due to rust. $100 plus shipping.
If you don't like the prices, make an offer. All parts located near zip 53566 Monroe, WI. Reply here or mail me at motherleopardihaveyourcub at yahoo dot com
Thanks,
Mark
Did your posts get deleted on the other forums because of a low post count or what?  I didn't think I was imagining it...I'm interested in the CC plates, and I may make an offer on them sometime soon here, I can get them at discount for being a corral.net member for 180 shipped, so I think the price would have to come down.
Long time Turboford freak...
84 SVO
88 TC
87 XR4Ti
