Topic: Power window switch and others... (Read 1448 times) previous topic - next topic
While I'm going over the cabin wiring in the '83, I remembered my window switch is pretty py (one mount broken off and the wiring itself is a but suspect.  I'm looking for a good power window switch and about 4-6" of wire pigtail.
Also, I need a couple of the upper radiator brackets...I seem to have misplaced mine.  I can use pretty much any Fox type(2.3, 3.8, 5.0) as my ele. fan is mounted differently than the stockers.
Chuck
cwarren@indy.net
I may have the upper radiator brackets, I will double check and let you know.
:birdsmily: Nate Wenck
Carroll IA
nwenck@msn.com
07 Suzuki Boulevard C50T
2003 Ford F-150 Supercrew
I should be able to help out w/ the switches, give me a couple days to get back to my parts car.
*EDIT*
I found the switches in my box o stuff.  I should be able to help w/ the wiring, too.  Give me until friday for sure on the wiring.
1987 Thunderbird 3.8. Sold :(
Got the harness too.  You have a PM.
Ok, I have located the switches.
Still looking for the rad brackets.
Quote from: Chuck W
Will these work?  $15 plus shipping.
Carroll IA
nwenck@msn.com
Ok, well I have some rad brackets on the way, but am still looking for a switch.
Actually what I really need is the electrical connector that plugs into the switch and about 6" of pigtail.  The catch is, these connectors are pr0ne to breakage, so I'm looking for an unbroken (or minimally cracked one).  Pics prefered if they are cracked.
bump
I'll check the parts TC next time I'm at the cottage for the condition of that harness. 87 is the same as 83, right?
Quote from: Thunder Chicken
NOt certain.  I haven't compared the two myself.
I know I've got 83 switches in my 88, and the only difference is that when you push the switch down (forward)  the window goes down but when you pull it back it goes up. Before I installed the '83 console it was the opposite - push forward for up, backward for down. This could, of course, be fixed by repinning the harness, but I prefer pulling back to bring the windows up (feels more natural)
Well I just switch need the connector/pigtail.  I don't need the switch itself.
I thought the only difference is the switch was bolted in upside down?
