Topic: Hey Thunderchicken (Read 798 times) previous topic - next topic
Hey Thunderchicken
I just installed your sequential turn signal kit and it works great:D . I found out something interesting though. Did you knw that if you wire the input to the outer turnsignal wire that the lamp out light blinks with the signal? On the left side I wired it to center lamps signal wire but I didn't have enough wire on the right side so I wired it to the out lamps signal wire. So when I put the left signal on the lamp out light dosen't blink but when I put the right one on the lamp out light comes on untill the center light comes on then it goes out and dosen't come back on till the cycle finishes. I think that the little black suitcase thing on the center turn light wire has something to do with checking to see if a turn lamp is out. Just letting ya know incase you've never seen this. But the kit works great and looks pretty darn good too:D .
